Thread: Advise sought before I pay Audi for diagnosis - Wiper Power Supplies
Results 1 to 8 of 8
  1. Advise sought before I pay Audi for diagnosis - Wiper Power Supplies
    Dec 2011
    Portsmouth, UK
    Hi All, I've posted about this before, but haven't had any replies yet. I changed the front wiper linkage a month ago, and ever since the wipers will only operate for 4 seconds in every 20. They don't park, they just stop wiping wherever they happen to be after 4 seconds. Evenm operating the 'single wipe' by pushing down on the stalk makes them operate for 4 seconds.
    I've checked that the park sensor in the motor works OK. The voltage on the supply witing loom seems to be at fault - the voltage on pins 3 & 4 is pulsing on for 4 seconds and then off for 16.
    I changed the relay, but that didn't change anything.
    In this dreadful, wet weather, the car's virtually undrivable, so I'm going to have to pay Audi to try to diagnose the fault - the best part of £100.
    So, before I do that, can anyone suggest what else I should check? Is the power supply operating properly? What else might I look at?
    All advice gratefully received!
    Thanks. (I've copied this to the A4 forum, as I think the wiper mechanism is the same)
  2. Re: Advise sought before I pay Audi for diagnosis - Wiper Power Supplies
    Dec 2009
    southampton uk
    Were they OK before?Maybe theres a fault in the stalk
  3. Re: Advise sought before I pay Audi for diagnosis - Wiper Power Supplies
    Dec 2011
    Portsmouth, UK
    No, they were absolutely fine before I changed the linkage (except that they were really stiff & slow).
    The precise timing of the voltage supply cutting in and out is what's confusing me the most.
  4. Re: Advise sought before I pay Audi for diagnosis - Wiper Power Supplies
    Dec 2009
    southampton uk
    Thats weird seems like its stuck on slow intermittent phase thats why I wondered if it was the stalk
  5. Re: Advise sought before I pay Audi for diagnosis - Wiper Power Supplies
    Dec 2011
    Southsea, United Kingdom
    Palee, I see you're in pompey also, I have a vagcom setup you're welcome to use if you want to pop over? I am not a vagcom 'expert' merely just an amateur. PM if you want
    Sep 2009
    ramsgate
    I had similar issues
    It turned out to be too much resistance through over tightning something to tight
    Try disconecting the linkage at the motor and see if the motor still does the same
    If not you need to release and grease up all the connections/joints
    Don't over tighten the motor mount or any fixed linkage as the rubbers have some flex in them to allow the linkage to run without resistance
    It's a fail safe for the motor, just like the electric windows
  7. Re: Advise sought before I pay Audi for diagnosis - Wiper Power Supplies
    Oct 2009
    London
    I remembering reading something about this.
    If I remember correctly, there is a small lever on the wiper motor which needs to be set in the correct position for the wipers to operate correctly. I saw mention of it in a how-to on replacing the linkages.
  8. Re: Advise sought before I pay Audi for diagnosis - Wiper Power Supplies
    Quote Originally Posted by palee View Post
    Hi All, I've posted about this before, but haven't had any replies yet....
    Please don't do this - it clutters the forum and it confuses people when they're searching for similar issues - I've removed the other 3 threads.
  1. 2001 - (Y) 100BHP Passat Below Full Power Fault - Diagnosis Help Please!
    By rjsdavis in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-02-2010, 08:39 PM
  2. Audi A6 Fault Diagnosis Help...
    By biker_billy in forum VCDS - Help Requests
    Last Post: 30-09-2009, 06:33 PM
  3. VW parts supplies
    By passat 1 b5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2009, 03:50 PM
  4. Audi new boy...advice, thoughts, opinions sought...
    By Tricky11 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2008, 12:32 PM
  5. I will pay £50 for a Golf TDi diagnosis
    By mistuart in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-05-2007, 02:51 PM
