Thread: Odd Clutch issue 2007 Passat B6
  1. Odd Clutch issue 2007 Passat B6
    Feb 2007
    Hi all,
    I have a 2007 105BHP Passat B6 and have an odd clutch issue with it. When you start the car in the morning the clutch pedal has dropped down about half way and the bite point is virtually on the floor but after a couple of miles it gradually comes back up to the top which is where is normally is. Obviously the piston below the pedal has dropped for this to happen but not sure why? I know its a hydraulic clutch and read somewhere that it gets it fluid from the brake reservior but this level hasn't dropped. My dual mass flywheel is on its way out but I've never experienced this before when they go. Any takers? Cheers!
  2. Re: Odd Clutch issue 2007 Passat B6
    Norfolk
    There is a fair chance that the friction plate is very worn, so the slave cylinder has to move a long way. You may even find the pedal going to the floor and refusing to come back upuntil you pull it with your toe.
  3. Re: Odd Clutch issue 2007 Passat B6
    Feb 2007
    Thats a good idea. The car is on 110,000 miles with original clutch I think so could be a possibilty. It's weird how it only does it some of the time but it is getting worse. I feel a new clutch/DMF on its way
  4. Re: Odd Clutch issue 2007 Passat B6
    Feb 2007
    Well, had the clutch/flywheel changed today and it was knackered but the odd pedal travel seemed to be down to a leaky salve cylinder. When they came to bleed the clutch it wouldn't do it as it was sucking in air. All changed and problems now solved. Thanks again for everyones help. Hope this helps someone one day.
  5. Re: Odd Clutch issue 2007 Passat B6
    Apr 2010
    Ashford, Middlesex
    Can I be cheeky and ask how much it cost you?
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  6. Re: Odd Clutch issue 2007 Passat B6
    Feb 2007
    I paid £400 on Ebay for the Sachs Clutch/flywheel and it was fitted for me along with a slave cylinder for £350. Think the slave cylinder was £50.
  1. Odd brake issue after hard braking
    By dysonco in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-12-2011, 12:38 PM
  2. Rear Suspension Issue on 2007 Audi SE Saloon
    By James1965 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-02-2011, 09:53 PM
  3. Passat 1.9TDI 2007 clutch/gearbox noise
    By bman20 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-09-2010, 03:56 PM
  4. VW passat tdi 1898 clutch issue?
    By paulnemo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-11-2009, 08:17 PM
  5. Question Odd Electrical issue - 2.0E ABK 1992
    By muz666 in forum 80 - 90
    Last Post: 29-09-2008, 10:10 PM
