Thread: passat 1999 no reception on AM station
Results 1 to 10 of 13
  1. passat 1999 no reception on AM station
    Jul 2007
    all the AM station has no reception , i did change the antenna still not working ????
    need help
    thanks
  2. Re: passat 1999 no reception on AM station
    Dec 2006
    Wiltshire
    Is this a saloon or estate? On the roof mounted antenna's the AM only works if you have 12v fed down the centre core of the aerial lead. In fact the amplifier for the screen mounted aerials also requires this...
    The factory radio provides this as standard - an aftermarket one doesn't.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  3. Re: passat 1999 no reception on AM station
    Jul 2007
    ok this is the factory radio with cd changer, I bought the car new in 1999 and I can't remember the last time I did listen to AM station but it was working, fm cd and tape work fine...now any suggestion??? the FM reception also is poor but working
  4. Re: passat 1999 no reception on AM station
    May 2007
    knee deep in clunge
    14 Post(s)
    The aerial base in the roof is favorite
  5. Re: passat 1999 no reception on AM station
    Jul 2007
    how can test the base?
  6. Re: passat 1999 no reception on AM station
    May 2007
    knee deep in clunge
    14 Post(s)
    if you disconnect it and plug any aerial you can find that fits into the main cable
  7. Re: passat 1999 no reception on AM station
    Jul 2007
    the antenna was replace a month ago
  8. Re: passat 1999 no reception on AM station
    banbury,oxon
    my favorite would be airel base....they all seem to go.....if you go to www.passatworld.com and type in "poor reception" on there search, there is a lot of info there..........
    lee
    B5 passat needs a supercharger and does'nt leak
  9. Re: passat 1999 no reception on AM station
    Jul 2007
    thanks for the tip. someone on that web site is talking about coding, check the coding with VAG COM and it was (05407) for a passive antenna ...how do check if the right coding is program
  10. Re: passat 1999 no reception on AM station
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by baloo51 View Post
    I said base and coding will not do anything to the reception you have either got a short to earth in the coax,faulty radio or faulty base as thats the full circuit
  1. Removal of carpets - Passat 1999
    By EwanJon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-07-2007, 05:43 PM
  2. 1.8 1999 passat fuel consumptio
    By VWman101 in forum Passat - Archive Topics
    Last Post: 24-06-2007, 10:52 PM
  3. central locking on 1999 passat 1.8 SET
    By r1ytm in forum Chat - Anything with wheels
    Last Post: 15-03-2007, 10:53 PM
  4. passat v6 4motion 1999[t]
    By mugsymilne in forum Archive posts
    Last Post: 02-02-2007, 06:40 PM
  5. 1999 VW Passat TDI
    By anguss in forum Archive posts
    Last Post: 16-10-2006, 10:15 AM
