Thread: Audi A4 b5 starting fault immobiliser LIGHT
  1. #1
    Jun 2010
    Lincoln, Lincolnshire
    You'll need a new transponder chip. Or a new key if you can't remove the chip from the key.
    Sent from my HTC Desire HD using Tapatalk
    Headlight Conversion, 2x8000k HID kits, De-cat downpipe, .216 Nozzles Boost Gauge, Colour changed on climate control and all buttons, LED instrument cluster, LED number plate lights, LED rear/brake lights, Lowered 40mm on SPAX springs. Soon to have GT1749VA
  2. Re: Audi A4 b5 starting fault immobiliser LIGHT
    Dec 2011
    Manchester
    Hi Josh same happened to me this time last year, I know there might be other solutions but I ended up going to main Audi dealer to get re-programmed.
  3. Re: Audi A4 b5 starting fault immobiliser LIGHT
    london/ UK
    Coil reader wiring loom is a common failure on the pre-facelifted b5 model, the loom is cheap from dealer- under 20 quid but requires steering wheel removal !
  4. Re: Audi A4 b5 starting fault immobiliser LIGHT
    Nov 2009
    Newcastle upon Tyne, England.
    Quote Originally Posted by adamss24 View Post
    I've got the same problem and bought the replacement loom (part number 8D0 972 275) from Audi. What's the best way to go about fitting it?
    Thanks.
  5. Re: Audi A4 b5 starting fault immobiliser LIGHT
    london/ UK
    Quote Originally Posted by chris_r View Post
    Thanks.
    Clue was in the post: remove steering wheel so you can get the cowling off ! A good long reach phillips screwdriver will help you remove the screws either side of the height release lever. you would also need a 5mm alen key and make sure you don't put the ignition on whilst the airbag is off. Mark position of the steering wheel to the steering column and do not turn the airbag slip ring- tape it if necessary...
  6. Re: Audi A4 b5 starting fault immobiliser LIGHT
    Nov 2009
    Cheers. Found some photos here:
    DIY: B5 A4 - Ignition Switch Replacement
  1. Immobiliser/Starting Problem
    By alan2721 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-11-2010, 03:30 PM
  2. Immobiliser Starting Fault New Passat
    By mel@tinystaxis. in forum New Member Introductions
    Last Post: 24-11-2010, 03:45 PM
  3. Newbie and A4 immobiliser/starting problem
    By alan2721 in forum New Member Introductions
    Last Post: 08-11-2010, 09:24 PM
  4. Immobiliser and hard starting. HELP!!
    By Darren VWPassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-06-2007, 02:19 PM
