Thread: 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    Feb 2010
    luton uk
    its back ( the dreaded management light that is ) done a code read with vcds lite today and got this error showing up -16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit P0130 - 35-10 - - - Intermittent-, have replaced both lambda sensors in past 3 months any ideas greatly appreciated
    thanks trev
  2. Re: 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    2014 Post(s)
    Which year and engine code?
  3. Re: 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    Feb 2010
    luton uk
    yr is 2001 and engine code is azm
  4. Re: 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    2014 Post(s)
    Check fuse 29.
  5. Re: 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    Feb 2010
    luton uk
    is this fuse located in the fuse panel on drivers side or is it under the bonnet ?? sorry for my ignorance
  6. Re: 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    2014 Post(s)
    On the side of the dash.
  7. Re: 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    Feb 2010
    luton uk
    i shall go look soon when i go out cheers crasher
  8. Re: 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    Feb 2010
    luton uk
    have checked fuse and fuse is ok . sensor is only 5 months old from gsf have been told i can exchange it for another one on production of mot emissions print out so whinged about the fact the cost would be as much as just buying a new one lol so then got told i can just bring a print off from vcds instead (must be their xmas spirit) lol
  9. Re: 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    2014 Post(s)
    I had this with a sensor for a very similar engine and it was made by Beru. Do you own a multimeter?
  10. Re: 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    Feb 2010
    luton uk
    i do have a multimeter . i have also used 1/2 tank of fuel in 4 days and done about 45-50 miles on it . grrr
  1. Oxygen (Lamba) Sensor fault code........
    By rallyfreaks in forum Golf MK4 - 1999 - 2004
    Last Post: 23-08-2011, 01:20 PM
  2. Please Help Drinks too much diesel :( Lambda/Oxygen Sensor)
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-03-2011, 07:08 PM
  3. oxygen sensor(lambda) 1.8T petrol
    By gazzap in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-05-2009, 09:31 PM
  4. Lambda / Oxygen sensor for S4...
    By Senlisian in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-11-2008, 12:38 AM
  5. Oxygen/Lambda sensor
    By dazaudi in forum 80 - 90
    Last Post: 04-04-2007, 07:10 PM
