Thread: What are the hose clips on VAG heater pipes called(ie not jubilee but...)?Tool required.
  1. What are the hose clips on VAG heater pipes called(ie not jubilee but...)?Tool required.
    Mike McKinstry Guest
    After a few years using large plumbers pliers to clamp up these vw hoses to remove them now we have a second vehicle in /hold using these clips (Seat)
    I am looking at trying to get the correct tool to open these clips but have no idea of their correct name?
    If anybody knows where I could purchase a budget tool to open/replace these would be appreciated.
    The clips are much more difficult to get to on Ibiza as they are tight to bulkhead.
    Thanks,Mike
  2. Re: What are the hose clips on VAG heater pipes called(ie not jubilee but...)?Tool required.
    Oct 2005
    If you mean the metal spring clips, there's VW tool VAG 1921
    Or you can use one of the alternatives.
    Snap On - http://buy1.snapon.com/catalog/item....uk&dir=catalog
    Sealey - http://www.sealey.co.uk/PLPageBuilde...roductid=11756
    Draper do a remote one if access is tight - Expert 230mm Flexible Ratchet Hose Clamp Pliers 89793 RHCP1
  3. Re: What are the hose clips on VAG heater pipes called(ie not jubilee but...)?Tool required.
    Thank you -looks like some more tool shopping.Had to buy first spline bit set this week to do door locks.
    Many thanks.
  4. Re: What are the hose clips on VAG heater pipes called(ie not jubilee but...)?Tool required.
    Pembrokeshire
    22 Post(s)
    get the remote one, makes life soooooo much easier.
  1. Please Help A4 B6 1.8t Hose Elbow - Part No. Required
    By steveheather in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-05-2011, 03:04 PM
  2. Question Aux heater flow & return pipes.
    By drodders in forum Touran - Sharan - Caravelle
    Last Post: 24-03-2010, 10:34 PM
  3. Please Help Can some one tell me what this tool is called.
    By 05FSI in forum Golf MK5 - 2004 - 2009
    Last Post: 26-02-2010, 08:15 PM
  4. vw bora axle tool required
    By niteman in forum Bora - 1998 - 2005
    Last Post: 07-09-2009, 08:23 AM
  5. Audi Hose Clips!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-04-2008, 12:07 PM
