Thread: Audi 80 water leak
  1. Exclamation Audi 80 water leak
    stillgrinning Guest
    Found that I have 2 identical leaks coming in to the front footwell at both sides. This appears to happen when the car is parked sloping backwards with heavy rain.
    I presume that it is getting in each side to the of the well just below the wipers.
    Does anyone have any information regarding this problem.
    Thanks Chris
  2. Re: Audi 80 water leak
    Jun 2007
    Gwent
    Get an assistant to pour a watering can around the area, and see if it is coming in the fusebox, or blower intake, check the drains are clear, could also be where wiring and cables go through the bulkhead, eg grommet missing?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Audi 80 water leak
    stillgrinning Guest
    If it is coming in around the Fuse box would the water track along inside and run down at the other side.
    Regards
    Chris
  4. Re: Audi 80 water leak
    Jun 2007
    Gwent
    Quote Originally Posted by stillgrinning View Post
    I think this would mean the water goes uphill, so probably not?
    I guess the windscreen seal could also be leaking.
  5. Re: Audi 80 water leak
    Feb 2007
    Bristol
    May be an idea to check your door seals around the wingmirror areas, as I have noticed water entering this area a few times in *v* heavy rain, eg. the past week!!
  1. water leak !
    By hitachi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2007, 08:57 PM
  2. water leak
    By johnmccoubrey@t in forum Alhambra
    Last Post: 23-06-2007, 10:45 PM
  3. Water Leak
    By silentwitness in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2007, 11:05 PM
  4. Water leak
    By toledotourer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-10-2006, 04:13 PM
  5. Sharan TDi water leak.
    By bxbxbx in forum Touran - Sharan - Caravelle
    Last Post: 04-10-2006, 01:43 PM
