Has anyone had this problem?
My car is very un safe with the ABS. You can feel a kick back through the break pedal. and breaking hard at speed it pulls all over the place. i have for the time being dissengaged it by taking the fuse out, much safer that way.
The 1st diagnostics said 1 of the wheel sensors was the problem, I replaced it and now the symtoms are worse than ever, and the diagnostics says the ABS pump is the problem.
But before i go to the expense of that I have heard it could be the ABS ECU.
Does anyone know where this is on TDI 80 estate 1994 ?
and has anyone got anyother suggestions ?
