Thread: Changing cluster for colour - who can do it in englad?
  1. Changing cluster for colour - who can do it in englad?
    Dec 2011
    Bournemouth
    Hi!
    I wasn't sure stick this post so if is not right place, please move.
    I bought new cluster clock (speedometer) for my Audi A4 1.8 T.
    I'm looking for somebody with knowledge and soft to do this. I will not explain what have to be done because if there is somebody with knowledge than hell know what to do.
    Best will be in Dorset as I live in Bournemouth, but not necessary.
    I know people in my country who can easily do this but its to far away to go there now only to this small job
    Any help, please.
    Thanks a lot
    May 2008
    Any Audi dealer.
  3. Re: Changing cluster for colour - who can do it in englad?
    Dec 2011
    Bournemouth
    In Audi dealer cost will be propably so high than is worth.
    Have to be private or small garage.
  4. Re: Changing cluster for colour - who can do it in englad?
    May 2007
    knee deep in clunge
    14 Post(s)
    if pre used just a problem with the mileage and also if b7 model you need to turn immo off for generation 3a immo so you need 3rd party software to do mileage and match/turn off immo
    if new clocks audi dealer no problem
    3a immo identity change normally requires a full replacement of keys (not to vin), dash and engine ecu as the vin can not be regenerated via diagnostic
    indi will not be able to do this unless thay have the correct immo and mileage correction software
    also only indi with inline subscription to fazzet server will be able to enable new das clocks immo and keys
    b7 clocks are not so easy for mileage correction and immo, you need to clone the engine ecu data to the dash for immo
  5. Re: Changing cluster for colour - who can do it in englad?
    Dec 2011
    Bournemouth
    Hmmm,
    I know what have to be done, because I done similar couple months ago when I changed 5 speed gear box for 6 speed.
    Old clock couldn't read speed from ABS. Only clock produced from July 2002 can do it.
    Was no problem to fit as a guy was a very clever man. Takes only 30 minutes to do it (cost me 40 pounds for his work).
    Both spedometer are immo RB4 not RB8. (another thing there is possibility to fit RB8 to RB4 but need knowledge and special soft and computers). Anyway is not on my problem as I have RB4.
    Need only read all info from old clock and computer put everything on new clock and recode immo on keys. I know its simple to write about what have to be done to sort issue but like I mentioned I've done that before :-)
    And one more thing. Clocks are used before not new one.
    May 2007
    knee deep in clunge
    14 Post(s)
    Rb4 straight forward you can do it yourself with correct software which can't be mentioned on The forum
    Sent from my iPhone using
    My fat fingers
  7. Re: Changing cluster for colour - who can do it in englad?
    Dec 2011
    Bournemouth
    Could you write little more on my email?
    adrian@adran.co.uk
  1. Question New Cluster
    By jedichi in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-11-2011, 10:30 PM
  2. colour change, what colour should i go
    By beevz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-11-2011, 07:50 PM
  3. gamma unit. changing or not changing ???
    By szczucse in forum In Car Entertainment
    Last Post: 17-07-2008, 01:51 PM
  4. wire colour wanted rear light cluster Passat
    By BARN OWL in forum Passat - Archive Topics
    Last Post: 25-07-2007, 07:47 PM
