Thread: 1999 2.5 v6 tdi - power cutting, possible pump timing
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. 1999 2.5 v6 tdi - power cutting, possible pump timing
    Aug 2010
    Warrington
    Its been power cutting with loads of white smoke when it does - and car seems more loud than other ones i have seen
    I have noticed its had the fuel pump changed at some point (breakers yard numbering on it)
    So i have been thinking its the pump timing
    Took me a while to find out how to do it, but i think i have done it
    basic settings group 04
    after 10 seconds it gos to full retard and zone 3 goes from 8degres btdc to around 15degrees
    Now should that be around 2 degrees not 15 ?
    ps just as a little side note, my car label tag in the boot says i have the AFB engine, but vagcom shows it as AKE.... does it do that or have a had a engine swap?
  2. Re: 1999 2.5 v6 tdi - power cutting, possible pump timing
    2021 Post(s)
    It should be 2° ATDC ± 2°, after top dead centre, not BTDC. Ignore the label on VAG-COM, it does that.
  3. Re: 1999 2.5 v6 tdi - power cutting, possible pump timing
    Aug 2010
    Warrington
    Thanks. Think i understand that
    So 15 degres is wrong either way?
  4. Re: 1999 2.5 v6 tdi - power cutting, possible pump timing
    2021 Post(s)
    Very much so.
  5. Re: 1999 2.5 v6 tdi - power cutting, possible pump timing
    Aug 2010
    Warrington
    Thanks crasher you save my sanity yet again!
  6. Re: 1999 2.5 v6 tdi - power cutting, possible pump timing
    Aug 2010
    Warrington
    ok
    I set about doing the timing this morning. i got it to around 1.5 atdc
    and it now runs worse!! the most amount of unburnt diesel smoke i have ever seen and it wont rev at all just chucks loads of smoke out?
    confussed i need help!
    heres my vcds
    Theres tipex marks every where under the belt cover. I think someones had the belts of and F'ed it up
    Its possible that pump timing is now right but cam timing is out?
  7. Re: 1999 2.5 v6 tdi - power cutting, possible pump timing
    2021 Post(s)
    That is because you have set it advanced (early), not retarded (late).
  8. Re: 1999 2.5 v6 tdi - power cutting, possible pump timing
    Aug 2010
    Warrington
    god... iam out of my depth here..... thank you crasher
    is this now right????
  9. Re: 1999 2.5 v6 tdi - power cutting, possible pump timing
    Oct 2011
    uk/germany
    Yes thats right on the Inj timing. Is it all sorted now? Reason I ask is that I found my injection timing advanced 15 degrees also and it turned out that the cam timing was out as well (by the same amount since it drives the pump). I brought it like that was so don't know whether it was set wrong or had slipped out of sync by a tooth on the crankshaft. Sorting that made it run like an audi instead of a tractor.
    So if its not 100% now do at least check the cam timing.
  10. Re: 1999 2.5 v6 tdi - power cutting, possible pump timing
    Aug 2010
    Warrington
    Thanks luke
    It now starts up pretty much straight away instead of about 8 cranks. Doesnt seem to be power cutting now, only a tiny bit of unburnt diesel smoke and now some black smoke, seems to have a fair bit more poke but still seems a bit more tractor sounding then i think a a6 should.
    Will have to try and find the proces for checking the cambelt timing and make sure its right.
  1. pump timing on AFB 2.5 tdi
    By johnbuz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-10-2010, 03:04 PM
  2. Please Help VW Golf 1.6 1999 - keeps cutting off and loss of power
    By nealzy in forum Golf MK4 - 1999 - 2004
    Last Post: 03-09-2010, 11:25 AM
  3. 2.5 tdi pump timing
    By jcbjames in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-12-2009, 07:26 PM
  4. A6 TDI AAT pump timing
    By putron in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-09-2009, 03:10 PM
  5. 1999 Golf 1.9 TDi injection pump timing
    By mistuart in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-05-2007, 07:26 PM
