Thread: A4 1.9Tdi 2002 quattro wont start in very cold weather
Results 1 to 10 of 12
  1. A4 1.9Tdi 2002 quattro wont start in very cold weather
    Jan 2011
    Dublin Ireland
    Hi Guys ,
    Having a problem with cold weather starting in recent temperatures below 0degrees. The fuel guage was showing quater full on one particular morning and am wondering would it have anything to do with condensation building up in the tank overnight. its very frustrating. Had a similar problem 2 years ago and the low pressure pump in the tank was replaced and now the problem is back again and has me thinking was there anything wrong with the pump in the first place. Glow plug lights go out when i turn the key and no other lights visable on dash. Battery was replaced 3 months ago. Hope its something simple. Any ideas would be appreciated
  2. Re: A4 1.9Tdi 2002 quattro wont start in very cold weather
    Dec 2009
    southampton uk
    How long dothe glow plugs stay on ? I would suspect them if its cold starting
  3. Re: A4 1.9Tdi 2002 quattro wont start in very cold weather
    Southern County Softy
    20 Post(s)
    try operating the glow plugs 3 or 4 times before cranking.
    A4 2.5 tdi QS (mapped)
  4. Re: A4 1.9Tdi 2002 quattro wont start in very cold weather
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by kite View Post
    Ditto this.. it's what I do when mine plays-up when trying to start.
    Also, unless you've already changed it recently, consider getting a decent quality replacement battery. Old ones that have been installed for many years suffer badly in very cold temperatures.
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  5. Re: A4 1.9Tdi 2002 quattro wont start in very cold weather
    Mar 2007
    Lancashire
    I'd go with a new battery too. I got a new one last jan as the other was still the original from 2001. My glow plugs could be 6-8 seconds in very zub zero, much better after the new battery. Cranking is better too and promotes a good start.
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  6. Re: A4 1.9Tdi 2002 quattro wont start in very cold weather
    Sep 2008
    6 Post(s)
    We had temperatures as low as -18 last year. Car would fire up no problem after glow plug light went out, so a few degees below shouldn't make any difference. I'd opt for replacing battery too. If want to check the existing battery - ensure the the electrolyte solution covers the plates. You can add distilled water if required.
    2016 BMW i3 REx (80k)
  7. Re: A4 1.9Tdi 2002 quattro wont start in very cold weather
    Sep 2008
    chester
    17 Post(s)
    I can see you've changed the battery,I would get the glowplugs out and see what sort of condition they're in,also in cold weather allow a longer preheat before cranking.
  8. Re: A4 1.9Tdi 2002 quattro wont start in very cold weather
    Sep 2008
    6 Post(s)
    Quote Originally Posted by nevo View Post
    Missed the bit about 'new battery'. If changing the glow plugs - assuming they've been in from new - worth getting car to operating temperature before trying to remove. The last thing you want is one breaking on you. Install with a slight smear of copper-ease on the threads.
  9. Re: A4 1.9Tdi 2002 quattro wont start in very cold weather
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by spartacus 68 View Post
    Apparently the glow plugs are an absolute nightmare to get out, especially if you've got a lump with high miles on it. Good hint on getting the engine up to temperarture though.
    I've heard nightmares about the tips falling-off into the combustion chamber - make sure you get a set of OEM glow plugs, I don't imagine it's worth saving a few quid in this area!
    Let us know how you get on if you do change your glow plugs. My 1.9 has covered 165k now and I'm not looking forward to the day I have to change the plugs!
    Toff.
    [ Past Audis:
    A6 S-Line 3.0
  10. Re: A4 1.9Tdi 2002 quattro wont start in very cold weather
    Sep 2008
    chester
    17 Post(s)
    You certainly do need to prey to the glowplug god and have everything crossed,give them some release oil and allow a few hours.
  1. A4 1.9TDI 130hp 2002 Quattro Wont start
    By A4flyer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-01-2011, 03:32 PM
  2. 2002 3.0 Quattro, cold start idle issues
    By Computageek in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2010, 11:33 PM
  3. Please Help HOT WEATHER - car wont start (no noises at all)
    By hornetcarp in forum Golf MK3 - 1993 - 1999
    Last Post: 23-06-2009, 09:52 PM
  4. A4 will not start after cold weather
    By tommurphy73 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-02-2009, 04:28 PM
  5. Won't Start in very cold weather
    By andrew_jmdata in forum Golf MK4 - 1999 - 2004
    Last Post: 30-12-2008, 08:06 PM
