Thread: A3 year 2001 rear fog light - how many
  1. A3 year 2001 rear fog light - how many
    Jul 2007
    I have an 1.8T sporty A3 hatch registered 2001
    Please can you tell me if it should have one or two rear fog lights.
    background:
    The passenger side fitting has the contact broken off but all terminals to rear cluster bulb holders have wires including one to the broken fog lamp.
    Tried replacing it with full cluster and fog does not work.
    (I have two reversing lights - thought it would be 1 reversing light and 1 fog
    or 2 of each.)
    Can't find any specs for the model's fog lights anywhere.
    many thanks
  2. Re: A3 year 2001 rear fog light - how many
    May 2007
    Bath, Wilts
    Quote Originally Posted by davetails View Post
    background:
    or 2 of each.)
    many thanks
    I've an Apr 01 TDI A3 SE. Just the one fog lamp works on mine. Yes the passenger side "appears" to be wired, but a small plastic blank is fitted instead of a bulb holder. Construction and use regs probably only state 1 is required for UK.
    It was the same on a Honda Civic I had, all wired up, but just Drivers side operating.
    Hope that helps?
    Trev McM
  3. Re: A3 year 2001 rear fog light - how many
    Canada
    One fog light is standard, i made the same mistake when i got my A4. you can cut the blank out and fit 2 if you wish, but probably not worth the hassle.
  1. 2001 face lift rear lights
    By littlejim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-07-2007, 04:56 PM
  2. 2001 Bora Oil warning light
    By jmcinerney01@ei in forum Bora - 1998 - 2005
    Last Post: 15-06-2007, 09:47 PM
  3. 2001 S6 - Rear facing seats - to be or not to be?
    By juliangranville in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-03-2007, 11:38 AM
  4. 2001 A4 ESP light stalling car!!! help.
    By bamjimpat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-02-2007, 05:06 PM
  5. Passat 2001 1.8T - ABS Warning Light On!
    By richard child in forum Passat - Archive Topics
    Last Post: 17-01-2007, 05:38 PM
