Thread: Changed Brake Fluid Yet Pedal Goes To Floor
Results 1 to 10 of 18
  1. Question Changed Brake Fluid Yet Pedal Goes To Floor
    Feb 2009
    Hi all.
    Need help!
    Changed my brake (and clutch) fluid today on my 2006 Passat TDI using a Vizibleed one-man bleeder. (clear pipe with a check valve in it).
    Clutch feels way better than it was before, nice low bite point again. The fluid that came out was disgusting (Yellow goo from the clutch, horrid brown from the brakes).
    The brakes pump up fine when stationary and the engine off. But when the engine is started (and the servo kicks in) the pedal sinks to the floor gradually.
    During normal braking the brakes definitely feel sharper, but a lower bite point. Under heavy braking the pedal goes all the way to the floor.
    What have I done wrong?
    Was it taking the fluid out of the reservoir with a syringe before I bled?
    Not a happy bunny, what was supposed to be a simple job has gone wrong!
    Sam
  2. Re: Changed Brake Fluid Yet Pedal Goes To Floor
    Dec 2009
    14 Post(s)
    Sounds like you have air in the system. I would suggest re bleading.
  3. Re: Changed Brake Fluid Yet Pedal Goes To Floor
    Dec 2009
    14 Post(s)
    Hows does the pedal feel? If spongy I would say you have trapped air.
    Hth's
    Rappy.
  4. Re: Changed Brake Fluid Yet Pedal Goes To Floor
    Feb 2009
    Bled them after a drive. Tiny bit better, but same story. Bled them RF, RR, LR, LF.
  5. Re: Changed Brake Fluid Yet Pedal Goes To Floor
    Norfolk
    Sounds like you need to completely bleed the system correctly.
  6. Re: Changed Brake Fluid Yet Pedal Goes To Floor
    Feb 2009
    how is that done martin?
  7. Re: Changed Brake Fluid Yet Pedal Goes To Floor
    Dec 2009
    14 Post(s)
    2 man job.
  8. Re: Changed Brake Fluid Yet Pedal Goes To Floor
    Feb 2009
    i have the one-man bleeder with the non-return valve, and tightly clipped over the nipple so no air gets in
  9. Re: Changed Brake Fluid Yet Pedal Goes To Floor
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    I've always found it's better to bleed & replace the brake fluid with a presure kit . Halfords sell a Gunson's kit which is quite inexpensive . I've had one for many years and use it quite often on the families cars without any problems.
    Skoda Octavia II SE 1.9PD TDI
  10. Re: Changed Brake Fluid Yet Pedal Goes To Floor
    Feb 2009
    hmmm might be an idea.
  1. Help.... clutch pedal on the floor and reservoir empty......
    By John in Norway in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-08-2011, 09:45 AM
  2. Please Help Brake pedal goes to floor
    By kezq in forum The Commercial Range
    Last Post: 21-05-2010, 11:06 AM
  3. Please Help Clutch pedal dropped to floor
    By VWJohn81 in forum Golf MK2 - 1984 - 1992
    Last Post: 09-04-2009, 08:25 PM
  4. Please Help clutch pedal gone to the floor
    By gt tdi fella in forum Golf MK4 - 1999 - 2004
    Last Post: 08-09-2008, 02:45 AM
  5. Brake Fluid, when was yours changed?
    By skymaster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2007, 01:33 AM
