Thread: Electronic parking brake
  1. Re: Electronic parking brake
    Parking Brake is now on & will not release. Have tried the battery disconnect method but with no success. Dealer has supplied me with a new switch in the hope that this will resolve the problem. Car is stuck in car park 30miles away so I will try tomorrow. Is it possible to release brake by applying voltage direct to caliper motor & if so which pins??
  2. Re: Electronic parking brake
    Norfolk
    NO ! You can release the epb by taking off the motor and backing off the central torx shaped caliper drive by one turn. Then refit the motors. Don't use the epb after that as it will probably jam again. The new switch might be all you need though.
  3. Re: Electronic parking brake
    Mar 2010
    london uk
    And use plenty lube and fit the motors in place before you thighten up the screws otherwise you do what i did and manage to break one of them,damn plastic thing.Goodluck and get the dealer sort out the prblm.
  4. Re: Electronic parking brake
    Thanks for all the help guys.... After much 'tinkering' (switch change did nothing) the RH caliper released but I had to unwind the LH. Not difficult but I would not want to do it in a supermarket carpark.. will have to tackle the dealer next week when it goes in for Injector check.. Why is it only Passats that seem to be problematic ?
  1. A6 Electronic Parking Brake
    By GLOVERGLOBAL in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-01-2012, 11:19 AM
  2. Question Electronic Parking Brake
    By airspark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-05-2011, 09:13 PM
  3. Please Help Fault in the Electronic Parking Brake !!!
    By yus786 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-11-2010, 04:31 PM
  4. Electronic Parking Brake
    By ondines_curse in forum Scirocco - 2008-
    Last Post: 19-09-2008, 09:55 PM
  5. Passat B6 Electronic Parking Brake
    By Iainrugby in forum Passat - Archive Topics
    Last Post: 09-11-2007, 10:27 AM
