Thread: Electronic parking brake
  1. Question Electronic parking brake
    2007,TDI 140,60,000mls
    I recently had my rear pads replaced and because they (main dealer) could not rewind the pistons I had to have both rear calipers replaced.(£700) Now,3 weeks later, whilst driving along the road the 'Parking brake fault' light illuminates.When I engage the brake only the RH functions.Switch off ignition & it resets till next time.The garage says the fault code suggests a voltage problem. The remedy is to replace the 'control module',£300-£400. Could a faulty rear caliper be causing the voltage problems...???
  2. Re: Electronic parking brake
    Norfolk
    Get the original dealer to sort it. Sounds like the controller is not happy with the values comming from the rear epb motors. It is unlikely you ever need two caliper motors and a controller. Point out to the dealer that you expect to pay for a fault repair, not for every possible part that might have caused it.
  3. Re: Electronic parking brake
    Thanks Martin. Car is booked in next week. I'm gathering more info by the day & hoping for a better diagnosis.
  4. Re: Electronic parking brake
    Parking Brake is now on & will not release. Have tried the battery disconnect method but with no success. Dealer has supplied me with a new switch in the hope that this will resolve the problem. Car is stuck in car park 30miles away so I will try tomorrow. Is it possible to release brake by applying voltage direct to caliper motor & if so which pins??
  5. Re: Electronic parking brake
    Norfolk
    NO ! You can release the epb by taking off the motor and backing off the central torx shaped caliper drive by one turn. Then refit the motors. Don't use the epb after that as it will probably jam again. The new switch might be all you need though.
  6. Re: Electronic parking brake
    Mar 2010
    london uk
    And use plenty lube and fit the motors in place before you thighten up the screws otherwise you do what i did and manage to break one of them,damn plastic thing.Goodluck and get the dealer sort out the prblm.
  1. A6 Electronic Parking Brake
    By GLOVERGLOBAL in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-01-2012, 11:19 AM
  2. Question Electronic Parking Brake
    By airspark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-05-2011, 09:13 PM
  3. Please Help Fault in the Electronic Parking Brake !!!
    By yus786 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-11-2010, 04:31 PM
  4. Electronic Parking Brake
    By ondines_curse in forum Scirocco - 2008-
    Last Post: 19-09-2008, 09:55 PM
  5. Passat B6 Electronic Parking Brake
    By Iainrugby in forum Passat - Archive Topics
    Last Post: 09-11-2007, 10:27 AM
