Thread: Hidden Menu
Results 1 to 10 of 10
  1. Hidden Menu
    Jul 2008
    Hello,
    A few questions.
    How do I enable the hidden menu in an A6 4f MMI 2g High to show the battery monitor.
    How would I also configure needle sweep and the lock confirmation chirp?
    Thanks!
  2. Re: Hidden Menu
    46 Post(s)
    You need VCDS/vagcom to do all 3 things you mention.
    Needle sweep will only work on the facelift 4F ~58 plate onwards.
    Hidden menu
    Module 07 - Control Head
    Adaption - Channel 008
    Set unit to 1.
    Reset MMI - Setup Central Control Wheel & inner right key
    Battery Meter
    Hold SETUP & CAR together for 2 or 3 seconds. It has a nack to get it right so try numerous times.
    Scroll down to DIAG settings
    Then Car Menus Maske
    Scroll to Battery meter, press control wheel
    Scroll down to bottom and save changes.
    Reset MMI as above.
    Press Car then Battery Meter
    Lock Chirp
    Module 46 - Comfort System
    Coding
    +2048 to the whole value given. You may need a calculator
    Test and save
    Lock car with keyfob
    *Whilst in the Hidden Menu, DO NOT go anywhere near Bootloader!!*
    Hope this helps
  3. Re: Hidden Menu
    Jul 2008
    Loverly! Thanks
    I wish I could have a needle sweep but oh well lol.
  4. Re: Hidden Menu
    Jul 2011
    London
    Could anyone help me connecting to my A6 4F (2009) model as I used to have a USB ODBII cable from Ebay and used VCDS-Lite to scan and code my Audi A4 B5 (2000) model but doesn't seem to work with my new A6. It does detect cable but reports that my car is not ODB-II compatible and suggests that if my car is Audi I should select Individual Controllers but not sure where to go from here.
    Also tried to get into Hidden Menu using the instructions above by pressing CAR + SETUP but doesn't seem to do anything whatever I try. Does it require some VCDS coding before it works?
    Finally any idea that how I could reset the SERVICE INTERVAL WARNING on Audi A6 4F (2009)?
  5. Re: Hidden Menu
    46 Post(s)
    Thread from the dead!!!
    Your cable is incompatible with your A6.
    You need HEX-USB-CAN - you need this one precisely - http://www.gendan.co.uk/product_VCHU.html
    Or you can contact NHN who is a forum sponsor and is a approved distributor for the above too.
    Before you can do anything you need the correct cable, your service light is reset with VCDS too.
    You need to look at the facelift section of this thread to stop any confusion with pre-facelift cars - A6 C6 VCDS Changes - Post & Pre Facelift
    1 1 0
  6. Re: Hidden Menu
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    Gup told me this in another thread but i can't remember which one...how do you set fog lights as DRL's in VCDS/VAGCOM? Just found out a mate has VAGCOM so will be borrowing it soon. Sounds like it's a bit technical, apart from going into bootloader is there any danger of completely ****ing it all up?
    57 A6 2.0 tdi 140 SE. Standard except for MMI Basic + and a remap by Expert Tuning, and a want list as long as the equator!
  7. Re: Hidden Menu
    46 Post(s)
    Fog Light as DRL (Facelift)
    See here about halfway thru or where I posted my screenshots.
    It wont work on facelift cars as they all have a dedicated DRL bulb on Halogen and Xenon 'lamps.
    Not technical at all, everything is reversible and logged. Just some basic sums and some tick boxes to master.
  8. Re: Hidden Menu
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    Thanks Chris. Mine is a pre facelift 07 though, is it the same process as in /\/\ thread?
  9. Re: Hidden Menu
    46 Post(s)
    Yes, just look at my screenshots and you're sorted.
    This post in particular - https://www.vwaudiforum.co.uk/forum/s...285#post825285
  10. Re: Hidden Menu
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    This post in particular - Fog Light as DRL (Facelift) - Page 2
    Cool, thanks mate.
  1. MMI 2g 5570 update & hidden menu
    By piotrek in forum In Car Entertainment
    Last Post: 26-02-2015, 07:07 PM
  2. Accessing hidden menu on MY2010 3G MMI
    By MFGF in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-09-2010, 07:55 PM
  3. Accessing hidden menu on 2g MMI
    By MarkBS in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2010, 03:34 PM
  4. Hidden Menu / Ignore region?
    By barryq7 in forum In Car Entertainment
    Last Post: 27-01-2010, 05:23 AM
  5. Hidden Features
    By PAULRYAN52 in forum The Commercial Range
    Last Post: 08-01-2008, 04:25 PM
