Thread: "Min Oil" light when oil is full, and now big red warning light
  1. "Min Oil" light when oil is full, and now big red warning light
    Sep 2011
    London
    About a week ago, the yellow "min" symbol with the picture of the oil can started appearing. I checked the oil and it was low, so i have filled it up to just below max. However, the "min oil" symbol is still appearing on every start-up.
    Just today, while driving, i also got a big red ((!)) symbol just below this. It stayed for a few seconds (with no noticable change in car performance) and then stopped.
    Is the red warning perhaps about the same thing; e.g. "Your oil is low, stop ignoring me!", or is it definitely a different problem?
    And why does it refuse to acknowledge that i have filled the oil up?
    Thanks.
  2. Re: "Min Oil" light when oil is full, and now big red warning light
    Dec 2009
    southampton uk
    What car ?The sensor may be stuck on does it go off after starting?The red light is a brake system fault possibly low pads
  3. Re: "Min Oil" light when oil is full, and now big red warning light
    Ayrshire, Scotland
    18 Post(s)
    if there is oil in it and we you are only getting the yellow oil can symbolThe min oil level error can be a faulty oil level sensor in the sump or also a faulty bonnet switch. Does the bonnet open show in the dash when its open?
    As mikey the red warning sounds like a brake Warning symbol if it shows only when cranking the engine it can be low power in your battery also.
    Regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  4. Re: "Min Oil" light when oil is full, and now big red warning light
    Sep 2011
    London
    Thanks guys, i'll check these things out.
  1. Please Help The dreaded "Oil Sensor Workshop" warning
    By adamski69 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-10-2010, 07:10 PM
  2. 1999 golf. RED oil warning light
    By ripple in forum Golf MK4 - 1999 - 2004
    Last Post: 19-06-2009, 11:14 AM
  3. "Check oil level" and yellow oil light
    By sergiup in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-10-2008, 12:06 AM
  4. 2.0 Oil MIN light (2001)
    By maxell in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2008, 11:14 PM
  5. Oil Min Warning Light
    By sossage in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-10-2007, 07:33 AM
