Thread: Golf 1.8t Gti ....Bad Smell
Results 1 to 10 of 12
  1. Golf 1.8t Gti ....Bad Smell
    Apr 2007
    BRISTOL
    Hi to everyone, I was wondering if anyone could help me with a bad smell i got in my Golf, It smells like i have a tramp in my car, It only smells when i first start the car and put the blower on cold or hot and also when i first put the air con on.. The smell goes after a short period but its a bit embarrasing if i give anyone a lift upon start up.
    I was advised to change the Pollen Filter, which i have done and although its a little better, still smells like the tramp has left his coat behind... LOL,
    No wet coming into the car and all the carpets are dry.
    Like i said its only on start-up and lasts only a few minutes.
    HELP
    Any Ideals!!!
    Trish x
  2. Re: Golf 1.8t Gti ....Bad Smell
    Midon Guest
    If it smells of bad eggs; then your catalytic converter needs looking at.!
  3. Re: Golf 1.8t Gti ....Bad Smell
    Verwood, Dorset
    The user manual on my climatronic states that once a week you should put it on auto and put the temp right down to low and leave it going for a while to blow the dust and debris out, or this will get damp and nasty smells will be produced...
    So perhaps u should try that regularly.. Hope that helps!
  4. Re: Golf 1.8t Gti ....Bad Smell
    Apr 2007
    BRISTOL
    Quote Originally Posted by sherlockuk View Post
    Many thanks for your advise, i dont have climate control just air con which dont give me the option of putting it on auto!
  5. Re: Golf 1.8t Gti ....Bad Smell
    Verwood, Dorset
    Well I suppose you could try running your A?C on max and full fan speed, would do the same thing i suppose. Also try making the flow go through all the vents, i.e. windo and floor and face wnts to clear them all..
    I know my old car used to blow all sorts through, but then it did not have a pollen filter
  6. Re: Golf 1.8t Gti ....Bad Smell
    Jul 2007
    Dorset, England
    Sounds like a dead rat in your heater matrix to me!
  7. Re: Golf 1.8t Gti ....Bad Smell
    Apr 2007
    BRISTOL
    Quote Originally Posted by Edwardo_TDI View Post
    I know im a woman, but....Its definetly not that !!!!
  8. Re: Golf 1.8t Gti ....Bad Smell
    Jul 2007
    Dorset, England
    Quote Originally Posted by trish View Post
    Haha, no worries, I only assumed that due to the "tramp-like" smell you described.
  9. Re: Golf 1.8t Gti ....Bad Smell
    Almost certainly, the bad smell is the Pollen Filter needing changing. I find that on all cars I've had (VW and non VW) the filter needs changing every two years maximum - sometimes every year. If this is the cause, the smell is most apparent when switching the a/c on (or when starting the car if it's always on). It smells really bad, like there's an old tramp in the car, as you describe.
    You can replace the filter yourself (i've just done mine on a Mk5 Golf TDI), no doubt the guru's on here will tell you exactly where it is and how to do it - it took me about half an hour, and included nothing more difficlt than undoing two fingers tight screws, and sliding a plastic cover off. No special tools (or tools at all) needed.
    The process is to simply renew the filter (available at the dealers or from a factors), but it pays to spray a anti-bacterial cleaner through the a/c system before replacing - nothing special here, I used a Dettol aerosol anti bacterial cleaner, about £3 for Tesco! Spray into the filter housing when the filter is out, with the a/c on low (fan speed) and allow it to recirculate through the car. The smell is caused by the bacteria which is killed by the spray.
    I now have a car which, whilst not smelling of roses, does not smell of old tramps! easy fix, and less than £30!
    Good luck.
  10. Re: Golf 1.8t Gti ....Bad Smell
    Apr 2007
    BRISTOL
    Quote Originally Posted by bw10030 View Post
    Good luck.
    Thank you for such good advise, will without a doubt be trying that, will let you know if it works, and get rid of that tramp for good!
    Once again Thankyou very much!
    Trish x
  1. Damp smell
    By pricey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2007, 05:14 PM
  2. A3 Air Con - Bad Smell
    By a33322 in forum Archive posts
    Last Post: 14-05-2007, 10:15 PM
  3. Burning Smell
    By sandman2309 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-03-2007, 04:50 PM
  4. VW Golf sweet plasticky smell
    By agiuga in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-12-2006, 09:18 PM
  5. Vw golf 1.9 TDI 04 - eggy smell
    By paulo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-10-2006, 02:21 PM
