Thread: MAF Cleaning?? Golf MK5 pdi. 48K miles.
Results 1 to 10 of 13
  1. Question MAF Cleaning?? Golf MK5 pdi. 48K miles.
    Mar 2011
    worcestershire
    I was having a problem of "Hot Starts" the engine was cranking but would not start as it
    normally does.
    Decided to remove & clean the MAF sensor with Isopropl and then Meths. Now OK.
    How does a dirty MAF affect Hot Starts??
  2. Re: MAF Cleaning?? Golf MK5 pdi. 48K miles.
    May 2010
    Devon England
    The hot start problem is normally the starter motor is turning slower than it should and needs to be replaced (mine needs a new one)
    cant see that cleaning the MAF would cure mine tho
  3. Re: MAF Cleaning?? Golf MK5 pdi. 48K miles.
    131 Post(s)
    1973 Post(s)
    A failed or dirty AMM should not affect hot starts, which engine code do you have?
  4. Re: MAF Cleaning?? Golf MK5 pdi. 48K miles.
    Bristol
    What could cause issues with hot starts? My parents car is a bit awkward when starting while hot, but is otherwise perfect.
    2002 Polo 9n 1.2 65PS. Basic but it's better than the train!
  5. Re: MAF Cleaning?? Golf MK5 pdi. 48K miles.
    131 Post(s)
    1973 Post(s)
    The reasons vary from one version to another, engine type specific.
  6. Re: MAF Cleaning?? Golf MK5 pdi. 48K miles.
    Bristol
    I don't know what the code is, but it's a 54-plate 1.9 TDI 105PS with the 5-speed, SE spec.
  7. Re: MAF Cleaning?? Golf MK5 pdi. 48K miles.
    May 2010
    Devon England
    Does the starter sound like its turning slowly? Yours is the same engine as mine a BXE it is a very common problem like I've said mines been like it for ages and at some point soon I will replace it
  8. Re: MAF Cleaning?? Golf MK5 pdi. 48K miles.
    131 Post(s)
    1973 Post(s)
    It can't be a BXE, that's 2006 onwards, it has to be BKC. Still, it could be low starter motor RPM, where the cranking speed does not reach the injection point in the ECU's map, first of all you must be sure there are no entries stored on the ECU, so have it fault code scanned first.
  9. Re: MAF Cleaning?? Golf MK5 pdi. 48K miles.
    May 2010
    Devon England
    Ops sorry been working on the oh's 57 105 tdi
  10. Re: MAF Cleaning?? Golf MK5 pdi. 48K miles.
    Bristol
    It sounds pretty normal tbh. Still, its worth mentioning it next time it's serviced. There's certainly no light on the dash, whether it's gone and stored something anyway is another matter. I'll let them know for next time it goes in, it's not a major issue as you just have to crank it for a bit longer than normal.
  1. Cleaning the MAF
    By ddave05 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2009, 03:45 PM
  2. cleaning maf
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-04-2009, 09:44 AM
  3. Cleaning Golf MK5 TDI engine
    By Mini Mark in forum General Detailing/Cleaning Questions
    Last Post: 28-02-2009, 02:15 PM
  4. Question MAF Cleaning
    By passat se tdi in forum Chat - Anything with wheels
    Last Post: 07-12-2008, 12:53 PM
  5. Please Help golf mk4 gt tdi 115 2001 48k miles gears
    By si24 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-09-2008, 10:53 PM
