Thread: Brake problems
  1. Brake problems
    Jun 2010
    Ireland
    The brakes work fine as do the ABS etc. however if I pump the brakes the pedal gets very hard after maybe two pumps and the brakes dont work very well. Anyone have any idea if this is normal and how it could be fixed.
    If its somethign thats going to deteriorate Id like to catch it early.
  2. Re: Brake problems
    Apr 2009
    Sounds like your losing servo pressure, check the pipes for air-leaks first
    Regards
    Jim
    Still Crazy After All These Gears
  3. Re: Brake problems
    Feb 2010
    luton uk
    have u had the common fault of water in bulkhead and recently resolved it , if so your servo could be rusting up inside like mine did after i'd drained bulkhead and removed bungs
  4. Re: Brake problems
    Nov 2011
    Swansea, South Wales
    Yeah, sounds like servo failure.
    Quick test:
    sit in car with engine off.
    pump brake pedal several times - until it goes hard.
    keep pressure on the pedal and start the engine.
    servo is working if the pedal moves towards the floor.
    if not, servo is not operating - check all vac pipes and vac pump before condeming servo.
  5. Re: Brake problems
    Jun 2010
    Ireland
    The servo is definately working and by plenum chamber is water and rust free. I would lean more to a vacum leak and will have a look over it and check the hoses.
  6. Re: Brake problems
    Co Durham
    Quote Originally Posted by Peter_HMR View Post
    When mine did that, I found a small vac pipe had become detached, it was under the fuel filter.
  1. A3 Brake problems
    By ford776 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-05-2011, 09:21 PM
  2. Please Help someone else with brake problems
    By bluerolo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2010, 10:24 PM
  3. Brake problems
    By BOWKER1000 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-04-2009, 07:08 AM
  4. t4 brake problems
    By aky31 in forum New Member Introductions
    Last Post: 05-10-2008, 01:15 PM
  5. Brake problems
    By kaptkv in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-04-2007, 10:57 PM
