Thread: HELP! Car doors won't open with remote or by key!
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. HELP! Car doors won't open with remote or by key!
    Jan 2010
    Belfast
    8 Post(s)
    Hi guys,
    I've just come back from a 3 week holiday and I'm not able to get access to my car. Neither of my two remote keys work and nor do the keys work in the door. Not even the boot. What is going on here??? Can this be easily fixed? Thank you!
    Car is: Audi A4 Avant 2002 (B6) 1.9 TDi Sport
  2. Re: HELP! Car doors won't open with remote or by key!
    What is happening when you put the key in the door? I would have assumed it's a mechanical lock, so it should turn the mechanism?
  3. Re: HELP! Car doors won't open with remote or by key!
    Apr 2009
    The car-battery has went flat on you, and the lock barrels have probably
    seized with under-use.
    Spray a little penetrating oil into the lock, or smear a little oil on the
    key blade, and jiggle the key about for a while.
    Regards
    Jim
    Still Crazy After All These Gears
  4. Re: HELP! Car doors won't open with remote or by key!
    Dec 2009
    southampton uk
    Why would all the locks seize in just three weeks?Is it the right key?!!Hope you have a recovery service
  5. Re: HELP! Car doors won't open with remote or by key!
    Apr 2009
    Quote Originally Posted by mikeybutch View Post
    It's perfectly normal for people not to put a key-blade into
    a lock barrel for years, why would they??
    Regards
    Jim
  6. Re: HELP! Car doors won't open with remote or by key!
    Dec 2009
    southampton uk
    I assumed the remote moved this so have just oiled mine
  7. Re: HELP! Car doors won't open with remote or by key!
    Jan 2010
    Belfast
    8 Post(s)
    Thanks for the suggestions guys. Unfortunately I still can't get access to the car. I tried oil on both keys and also on both the boot and the driver side lock but it won't budge. Yes, it's the right key alright because it starts the car ok! I need to try and sort this ASAP. I have the jump leads on standby but if I connect them will that somehow give me enough power to use the remote to get the doors open? The only thing I can think of is to temporarily fit a new battery so I can get access. Really don't know what else to try. Suggestions welcome. Thank you!
  8. Re: HELP! Car doors won't open with remote or by key!
    Dec 2009
    southampton uk
    If its the barrels stuck what about trying the spray you can use to free corroded nuts .Halfords sell one think its called Shock and Unlock.There would be a problem if you neede to open the bonnet from outside
  9. Re: HELP! Car doors won't open with remote or by key!
    Jan 2010
    Belfast
    8 Post(s)
    Oh yehah, I forgot about that :-(
  10. Re: HELP! Car doors won't open with remote or by key!
    Jan 2010
    Belfast
    8 Post(s)
    Shock and Unlock. Thanks. I'll try that :-)
  1. Sometimes Doors won't unlock now remote key fob is intermittent
    By andrew_jmdata in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2011, 08:37 PM
  2. second plip on remote to open other doors
    By arnieboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-01-2011, 10:33 PM
  3. key wont start car but opens doors
    By toddy2008 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-05-2010, 07:32 PM
  4. Cant Open All Doors With Key Fob (Drivers is OK)
    By neovw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2010, 11:55 AM
  5. Car not sensing that doors are open.
    By del_tl1000r in forum Bora - 1998 - 2005
    Last Post: 27-07-2008, 09:26 AM
