Thread: Golf MFD Menu
  1. Golf MFD Menu
    Nov 2011
    Essex
    Hi Can anyone help please.
    Have just purchased a Golf Match 1.6 Auto Bluemotion and I am a litle lost as to how to select use and amend and dispaly settings in the extensive menus for diplay in the multi function display. I find the owners manual to be very heavy and not helpfull. Can anyone help please. I am usually quite good with menu driven settings and can use a PC but this has me confussed. Is there "an idiot proof "how to do it" guide please. Many thanks
  2. Re: Golf MFD Menu
    South London. UK
    Quote Originally Posted by Agrima View Post
    More information please. Do you have the multifunction steering wheel with controls for audio system and the MFD? What exactly do you want to do? And KeithUk would want you to put your car's salient spec. as your signature.
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  3. Re: Golf MFD Menu
    Jul 2010
    Oxford
    The steering wheel controls are standard on Match.
    Use the left and right buttons to move between the main sections.
    Push the middle button to go into the next level of options, back button to go to previous level.
    The options are in Setup, which can only be changed when stationary.
    I recommend flicking through the options to see what you can change. If the name of the option doesn't make obvious what it does, then search this forum or post the question.
    The mfd screen is a fancy trip computer.
    It has two memories, you flick between them by a short press on the middle button. A long press resets the memory. Memory 1 is for the current journey. if the ignition is off for 2 hours it will reset itself. Memory 2 resets itself after 100 hours.
    Golf Match 2.0 tdi 140 Bluemotion tech, fogs, folding mirrors. Reversing camera didn't make it, so enjoying DAB.
    Other motor is a Nissan Pathfinder.
  1. Full MFD Settings menu...
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-01-2011, 08:57 PM
  2. MFD's: High MFD from Mid MFD
    Last Post: 25-05-2010, 10:16 PM
  3. passat b6 mfd/dis convenience menu
    By hartry in forum VCDS - Help Requests
    Last Post: 23-09-2009, 11:42 PM
  4. Golf MFD
    By vespapete in forum Archive posts
    Last Post: 19-10-2007, 05:53 PM
  5. VW Golf MFD Satnav problem
    By ALPORTER in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-04-2007, 09:17 AM
