Thread: Intermittent brake issue!!!!!
  1. Intermittent brake issue!!!!!
    Oct 2011
    llanelli
    Hi, i have a 2001 b6 1.9 tdi, owned for 4 weeks,
    had 2 kids and baby in car mon morning on school
    run, pulled up to junction meeting a 60mph bypass,
    braked and nothing! pedal was hard and only just managed
    to stop! lucky there was nothing coming! slowly dropped kids
    off and headed home.. went back out to car a couple of hours later
    and brakes were fine.. then, yest same and today after work..
    seems fine when car is warm? after stopping and restarting car!
    any suggestions?
    cheers in advance, richie..
  2. Re: Intermittent brake issue!!!!!
    Dec 2009
    southampton uk
    Sounds serious maybe the servo .I would get it to a garage asap
  3. Re: Intermittent brake issue!!!!!
    Sep 2008
    chester
    17 Post(s)
    It will be the servo internal corrosion get it checked over NOW you might not be so lucky next time and it will happen again.
  4. Re: Intermittent brake issue!!!!!
    Jul 2007
    somerset
    8 Post(s)
    My bets are on the plenum chamber rubber drain grommets being blocked with debris and causing the plenum chamber to flood with rain water during heavy rain. the water then gets inside the servo and causes it to rust internally.
    The drains are under the battery and under the servo, poke something through them to remove the blockage, or totally remove the grommets.
    This job needs doing asap the last thing you need is no brakes!! P.s i have heard of a few warranty claims for this work, might be worth a go.
  5. Re: Intermittent brake issue!!!!!
    Dec 2008
    I had this exact problem, it was blocked drains in the plenum chamber, a problem that was supposed to be sorted on a recall. The water was high enough to get into the brake servo unit and knackered it, leaving the brakes with no assistance, like there was a brick between the pedal and he floor. Went to Audi and shared my safety concerns with them, they sorted the drains and replaced the brake servo free of charge, must have been 4 or £500 worth of work, which was nice! The fact is that it is a serious safety issue, caused by a fault known to Audi, which should have been sorted already. Try your luck at a couple of dealerships, worth a try.
    55 Audi A3 1.9 TDI 105 se....frugal
  6. Re: Intermittent brake issue!!!!!
    May 2009
    County Durham
    I had the same issue a few weeks ago and it turned out to be a vacume hose with a big hole in. New hose on and brakes are spot on now.
  1. Intermittent starting issue
    By Todri in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2011, 05:54 PM
  2. Intermittent Loss of Acceleration issue
    By Fatimoo1 in forum Golf MK5 - 2004 - 2009
    Last Post: 04-01-2011, 06:31 PM
  3. 1999 A4 Intermittent Interior Light Issue
    By skelly180868 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-12-2010, 11:14 PM
  4. Please Help Climate control- intermittent issue
    By reevelee in forum Golf MK5 - 2004 - 2009
    Last Post: 01-08-2010, 08:44 PM
  5. Please Help Polo 1999 1.4 CL, intermittent clutch issue
    By crauch6 in forum Polo - Derby - Lupo - Fox
    Last Post: 30-01-2010, 03:46 PM
