Thread: White Smoke
Results 1 to 10 of 10
  1. Angry White Smoke
    Jul 2007
    I HAVE A 2001 VW SHARAN 130 PD ENGINE AND IT IS GIVING OUT WHITE SMOKE & THE SMELL OF FUEL. I HAVE HAD THIS PROBLEM SINCE I GOT THE HEAD DONE AND REPACED THE TURBO AT THE SAME TIME. I HAVE BEEN TOLD IT IS THE TURBO BUT THIS IS THE SECOND BRAND NEW TURBO IV HAD FITTED IN ONE WEEK.
  2. Re: White Smoke
    7 Post(s)
    Could be all manner of things.
    What has previously happened to warrant having a new turbo etc?
    It does quite obviously appear to be overfuelling, the trick is to find out why.
    Can you get it read for faults, look in the vagcom subforum for someone who may be able to help.
  3. Re: White Smoke
    Jul 2007
    When i got the head done and got car back from garage it had no power. So over the next few weeks it was in and out of garage to find out what was wrong. It was drivererbel just no power. At this point it was not smoking or buring fuel. I got told when it went onto a diagnostic that its all pointing to the turbo so i asked garage to take it off. When it was removed from the vehicle we found out that the finns were damaged and ther was a lot of play in the shaft. I decided to buy a new turbo and when it was fitted the vehicle started with the white smoke problem. The garage said it is the turbo leaking oil from the seals and the turbo had to come off againe. The turbo went back and was replaced for another new one and was told that the first one was faulty. Now iv had the second one fitted and the car is still smoking but this time it has the smell of fuel
  4. Re: White Smoke
    Bristol
    is this garage a VW dealership or just a Joe bloggs car repair workshop ?
  5. Re: White Smoke
    Jul 2007
    I have had it on machine and it comes up with no faults
  6. Re: White Smoke
    london/ UK
    Is the engine running ok, any misfires ? White smoke usually means that its has a blown head gasket and its burning coolant. But it could be overfueling because of coolant temp. meter (usually black smoke !) or a shot injector or low or no compression on one of the cylinders. Have the garage do a compression test or a leak down test.
  7. Re: White Smoke
    Jul 2007
    Engine was running ok but head needed doing as it was building presure and loseing water. I have had the head done by a enginering firm near us and since then it been giving white smoke and burning fule. I have had a compression test done a few days ago and its been on coputer to see if it comes up with any faults but it is coming up fine.
  8. Re: White Smoke
    131 Post(s)
    1973 Post(s)
    Is it using water? Excessive fuel would be black smoke. Was the original head re-used or an exchange replacement?
  9. Re: White Smoke
    Jul 2007
    The original hed was used and its not building any presure since i got the head done or using any. The smoke is white and smell is like unburnt fule.
  10. Re: White Smoke
    131 Post(s)
    1973 Post(s)
    Can you PM me the chassis number?
  1. 2002 tdi white smoke ?????
    By mullac in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2007, 11:20 AM
  2. 80 Tdi with a lotta white smoke
    By ghee60 in forum 80 - 90
    Last Post: 03-06-2007, 08:25 PM
  3. white smoke from sharan
    By pencastle in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2007, 04:20 PM
  4. White Smoke
    By Speedy in forum Touran - Sharan - Caravelle
    Last Post: 05-01-2007, 11:44 PM
  5. 97 a4 1.8 turbo white smoke
    By spjmm0 in forum Audi A4 - Archive Topics
    Last Post: 31-07-2006, 02:57 AM
