Thread: Gearbox - can't always select reverse!
  1. Exclamation Gearbox - can't always select reverse!
    Nov 2008
    Hi, ive got a late 2005 VW Polo 1.4 TDI.
    I was up in London this weekend when I couldn't select reverse gear, the gear stick became really stiff when pushing it down and to the left, and if I forced it, it would only go into first.. Rocked around for a minute or so on the spot and it started working fine! thought nothing more of it at the time - but yesterday I had the same problem accept this time it last a good few hours until driving it back from the garage today, again it seemed to self correct!
    No problems with any other gears. No unusual sounds at all. Clutch is fine. Makes no difference if you turn the engine off. As I mentioned, the handle goes stiff when trying to select reverse, and if you force it in, only selects first. The guy at garage took alook at the selectors on the top of the box and he seemed to think it was fine, and could only suggest taking the gearbox out, either opening up or just replace with a second hand.
    Can't really afford that, tempted to have ago myself, but any other suggestions, or places to look first?
  2. Re: Gearbox - can't always select reverse!
    May 2007
    knee deep in clunge
    14 Post(s)
    the reverse switch ball sticks on the selector shaft, try replacing the switch
  3. Re: Gearbox - can't always select reverse!
    Nov 2008
    thanks for the quick reply - where abouts would I find that? or is it a haynes manual job
  4. Re: Gearbox - can't always select reverse!
    May 2007
    knee deep in clunge
    14 Post(s)
    Attachment 15239depends which box as the reverse switch tends to be mounted on the selector housing for this fault so you may need to check the pr codes to find out which box you have
    see the picture number 6 is the switch
  5. Re: Gearbox - can't always select reverse!
    Nov 2008
    Hi, thanks for the picture - I took alook today and had felt around the selector, and it appears correct to the picture. My gearbox/engine code is BNV GGV, followed by LA5R WV. So I will try changing the switch this week. Im guessing it goes stiff because the selector isn't depressing the full distance, and then alittle flex in the cable is allowing me to force it in, but going into first instead. Thanks
    May 2007
    knee deep in clunge
    14 Post(s)
    Well done that's correct
    Sent from my iPhone using
    My fat fingers
  1. Help A3 Unable to select Reverse Gear
    By avitmark in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-11-2011, 12:10 AM
  2. Difficult to select first gear and reverse. Car shudders in reverse
    By robert1z in forum Golf MK3 - 1993 - 1999
    Last Post: 11-04-2010, 06:46 PM
  3. Question unable to select reverse gear
    By stan still in forum Polo - Derby - Lupo - Fox
    Last Post: 30-01-2010, 11:15 PM
  4. Hard to select Reverse & 5th gear
    By the_old_diver in forum Touran - Sharan - Caravelle
    Last Post: 06-12-2009, 10:54 PM
  5. Can't select 1st 2nd or reverse gear?
    By Lis in forum Golf MK4 - 1999 - 2004
    Last Post: 12-01-2009, 05:16 PM
