Thread: ESP not working 2002 Passat 1.8T
  1. Unhappy ESP not working 2002 Passat 1.8T
    Aug 2010
    Bridgwater
    I was wondering if anyone could help with a problem I'm having with my 2002 Passat 1.8T. A few weeks ago I was accelerating fairly hard & the ESP suddenly kicked in for a brief moment. It was like someone had hit the brakes for a split second - the car then continued to drive normally but the ESP light is now permanently illuminated. Shortly afterwards (say 10-15mins) the exhaust warning light also came on.
    The ESP light has stayed on & the ESP definitely is not working. The ABS however is working fine. Other than that the car feels fine.
    A colleague of mine at work has a diagnostic computer & managed to get some fault codes off the system (detailed below). He then erased the faults. The exhaust warning light has not illuminated again but the ESP light came on a few seconds after the car was started.
    Fault codes:
    Engine - 16486 - Mass Air Flow Sensor (G70) Signal too low – static – no indication on display
    ABS - 18265 - Load Signal: Error Message from ECU: P1857 – static – No indication on display
    I'm guessing that the air flow sensor is the cause of the exhaust light - if it comes on again I will change the sensor. I am also guessing that the ABS ECU error is causing the loss of ESP.
    Question is - what do I do next?! I have a basic knowledge & skill with simple mechanics (servicing, changing brakes etc) but I am by no means a mechanic & even less as auto-electrician! I am also on a budget however so a cheap solution would be preferred.
    If anyone can offer a further insight into this then it would be very much appreciated. If it proves too complicated or costly then I can live without ESP but obviously I would prefer it to be working.
    Thanks in advance,
    James
  2. Unhappy Re: ESP not working 2002 Passat 1.8T
    Aug 2010
    Bridgwater
    Update - The exhaust light came back on the next time I started the car.
    If anyone has any advice or can point me in the right direction then I would be really grateful!
  3. Re: ESP not working 2002 Passat 1.8T
    Aug 2010
    Bridgwater
    Last try - bump!
  4. Re: ESP not working 2002 Passat 1.8T
    Norfolk
    2 0 0
  5. Re: ESP not working 2002 Passat 1.8T
    Aug 2010
    Bridgwater
    Thanks martin1810! Does seem to be giving the same fault code as mine so will give this a try.
    Thanks again!
  1. Question Polo 2002 1.4 comfortline have ESP ?
    By BesTCooL in forum Polo - Derby - Lupo - Fox
    Last Post: 14-12-2009, 08:59 PM
  2. Please Help Passat 2.0S 2002 Brake Lights and Flat Battery with intermittent ESP / ABS warning light
    By tweever in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-10-2009, 01:50 PM
  3. 2002 2.0s Passat ESP / Key Fob / Remote Probs
    By martvwpas in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-04-2009, 11:01 AM
  4. coding ESP audi a4 2002
    By pati in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-11-2008, 02:32 AM
  5. Passat TDI 130 2002 Interior blower vent lights not working!
    By radek2008 in forum Chat - Anything with wheels
    Last Post: 19-10-2007, 07:00 PM
