Thread: A6 poor fuel economy
Results 1 to 9 of 9
  1. A6 poor fuel economy
    Jun 2008
    Hi, just recently purchased an a6 2002 model, lovely looking car and drives fantasticly well, its a 130bhp 1.9tdi with a full service record of which i have all receipts for work done, very powerfull for such a big car. the one thing i'm disappointed about is the mpg, i expected it to be above forty's going back and forth to work etc but i'm only returning 33mpg, should it be better, car runs very well otherwise.
  2. Re: A6 poor fuel economy
    Dec 2007
    It might be worth checking the egr valve or maf as it sounds a little low to me.
    I had a customer a while ago who had a passat giving a similar kind of mpg figure and when the customer just removed the egr valve pipe he gained another 3 mpg and after that he replaced the egr and the mph went up to around 40 mpg, if I remember correctly.
  3. Re: A6 poor fuel economy
    Jun 2008
    Dunfermline
    If it is the AWX engine then it is definitely low.
    I had my professionaly re-mapped to 169bhp and stll get 46mpg on a mixture of commuting and 70mph motorway work.
    I'm by no means an expert, but would suggest MAF and check all of the plumbing on the cold air side of the turbo for leaks. sounds like it is over-fuelling and if you're not getting the performance to match the fuel usage it may be worth looking for a smokey exhaust when engine is under load.
    Also worth trying a dose of Forte diesel treatment in case injectors clogged and not giving a very good spray pattern.
    Dozy
  4. Re: A6 poor fuel economy
    Jun 2008
    Quote Originally Posted by cctuning View Post
    thanks for the reply. will look more into that . thanks
  5. Re: A6 poor fuel economy
    Jun 2008
    hi, what is the significance of smokey exhaust when engine under load and what does engine under load mean?
  6. Re: A6 poor fuel economy
    Jun 2008
    Dunfermline
    Smokey exhaust means not enough air being supplied from the turbo to burn all of the fuel completely. can sometimes be caused by a leak in the pipework from the turbo, via the intercooler, into the engine, or a sensor giving the ecu duff info as to how much fuel to squirt in for a given engine speed / throttle position. The end effect is the same : too much fuel being burned without the corresponding power being produced. If you remember bunsen burners from school, when the air hole is closed, for the same amount of gas going through it you get a cool yellow sooty flame instead of a nice hot blue flame when the air hole is opened.
    A bit abstract maybe, but I hope you understand the principle.
  7. Re: A6 poor fuel economy
    Jun 2008
    thanks for the explanation, easy to understand, took me back to science classes at school and the carry on we had with bunson burners lol, but hey thanks again dozy.cheers billy g.
    Quote Originally Posted by Dozy View Post
  8. Re: A6 poor fuel economy
    Jan 2011
    Haverfordwest, UK
    33mpg? Luxury! I have a 2.7T (V6 2.7L twin turbo) & am lucky to get 23mpg:-(
    Sep 2009
    ramsgate
    Does the temp get get up to 90? If not you'll find the Ecu cant map the best fuel delivery because the ecu will think it's cold and still warming up.
    I'm no expert but i had the same problem with my A4 and Passat.
    Changed the notorious temp sensor and stat for £32 including 1.5lt G12 ++ and voila, now 45mpg mixed driving
    Money back in no time
  1. poor fuel economy
    By mick gracey in forum Polo - Derby - Lupo - Fox
    Last Post: 11-02-2011, 11:39 PM
  2. Please Help A4 1996 Poor Fuel Economy
    By simonb5a4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-07-2010, 08:19 AM
  3. Poor Fuel Economy
    By hidnmine in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 15-10-2009, 01:01 PM
  4. A4 B5 115bhp poor fuel economy
    By gorillamonsoon in forum New Member Introductions
    Last Post: 29-03-2008, 08:42 PM
  5. Mk3. Poor fuel economy?
    By Airplanner in forum Golf MK3 - 1993 - 1999
    Last Post: 26-08-2007, 08:50 AM
