Thread: 2008 Bi-Xenon Problem
Results 1 to 10 of 16
  1. 2008 Bi-Xenon Problem
    Nov 2011
    Dublin
    I've an a4 B8 with Bi-xenons.
    Recently the drivers side headlamp just switches off completely a few minutes after the car starts up. The LED's are fine.
    If I switch all lights off and back on again, it can come back on for a minute, or not at all.
    I've noticed that there is a slightly different (more white) colour off this driver's side lamp than the passengers. Previous owner may have had one replaced, but hard to know which!
    Could anyone shed some light on what may be happening. I presume the bulb/lamp is fine as it works intermittently, so could it be an overheating/power etc issue?
    Very frustrating.
    Thanks for your help
    May 2007
    knee deep in clunge
    14 Post(s)
    Its the bulbs and a known issue with a technical bulletin covering the compliant
    Both osf and nsf bulbs are replaced with revised versions
    Sent from my iPhone using
    My fat fingers
  3. Re: 2008 Bi-Xenon Problem
    Nov 2011
    Dublin
    Thanks for the reply.
    Could you please point me in the direction of a link to this bulletin.
    I found one relating to 2.0T, not sure if it's the same. I've a 1.8T.
    Also, what do those acronyms mean?
    Am I in big trouble expense wise?!
    Thanks again
  4. Re: 2008 Bi-Xenon Problem
    May 2009
    Edinburgh
    Off side front.
    Near side front.
    2010 Focus ST-3
  5. Re: 2008 Bi-Xenon Problem
    Oct 2011
    Surrey, Farnham
    8 Post(s)
    Quote Originally Posted by Dave471 View Post
    Thanks again
    I had EXACTLY the same problem as you on my 2008 Avant just 2 weeks ago, see this thread:
    https://www.vwaudiforum.co.uk/forum/s...-Bulb-Changing
    Audi wanted £149 + VAT + labour for 1 bulb (D3S) and of course recomended me to change both.
    I bought a pair on Ebay for £35 (with 1 years warranty) and they work brilliantly
  6. Re: 2008 Bi-Xenon Problem
    May 2007
    knee deep in clunge
    14 Post(s)
    as its 2008 then these solutions are for 8k B8 a4
  7. Re: 2008 Bi-Xenon Problem
    Oct 2011
    Surrey, Farnham
    8 Post(s)
    Is this something that shows up when running "fault codes diagnostic" using VAG-COM? This is what showed up when I got out my fault codes:
    1 Fault Found:
    00978 - Lamp for Low Beam; Left (M29)
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 15
    Reset counter: 149
    Mileage: 94207 km
    Time Indication: 0
    Date: 2011.10.29
    Time: 17:10:00
    Mine flickerd twice, then it switched off, and the colour was slightly "bluer"
    Works fine (so far) with the 2 new Ebay bulbs I bought and I must say, it wasn't too hard to change the bulbs myself, which I was worried about...
    May 2007
    knee deep in clunge
    14 Post(s)
    Your fault code related to the second technical bulletin on my post
    My fat fingers
  9. Re: 2008 Bi-Xenon Problem
    Oct 2011
    Surrey, Farnham
    8 Post(s)
    Hm, interesting, I still have both of the old bulbs (one faulty of course), I'll check the production date on them. Does this mean that I can go to my local Audi dealer (Camberley, Surrey) and get a replacement bulb free of charge? The car is now 2 months out of warranty, so I guess they'll just laugh at me for even asking right?
  10. Re: 2008 Bi-Xenon Problem
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by nowa View Post
    Ring the service department and raise the query, if they know of the bulletin then ask for a goodwill contribution, if they accept then refit the bulbs and they will change them
  1. A 2008 A4 B8 Bluetooth problem , plz help ! :(
    By Proteous in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-08-2011, 10:42 AM
  2. Please Help Audi A3 2008 58 Facelift...halogen to bi-xenon switch..now need vagcom coding help!!
    By Gan657a in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-07-2011, 10:58 AM
  3. Xenon problem
    By atz in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-06-2010, 11:45 PM
  4. Please Help-A8 Xenon Problem
    By Jonsie in forum A8 - S8 - V8
    Last Post: 01-04-2010, 08:51 PM
  5. Bi-xenon retrofit problem
    By ningloh in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-06-2009, 11:17 PM
