Thread: Water pooling in nearside rear passenger footwell
Results 1 to 10 of 16
  1. Unhappy Water pooling in nearside rear passenger footwell
    Nov 2011
    Leicester
    Water pools in the rear nearside passenger footwell of my Audi A6 SE Avant 1.9 tdi 2001. It is clean water, i.e. not coolant or screenwash. It is not dirty therefore not off the road. I have checked under the battery for drain holes blocked and there was no sign of water or debris in chamber. I have changed the pollen filter holder to ensure a new and effective seal. The foam lining to below the holder is clean and dry suggesting that water is not comming in through the pollen filter.
    Has anybody got any ideas what I can check next?
  2. Re: Water pooling in nearside rear passenger footwell
    Ayrshire, Scotland
    18 Post(s)
    Sounds like you have checked all the ussual areas, is it an Avant? If you are sure the washer system is not leaking, the plenum chamber drains are not blocked, the windscreen seal is OK, pollen filter seal, double checkthem all.
    I would suggest lifting the front carpet as the ccu is likely to be sitting in water and this will only lead to more issues, while the carpet is up try a hose on the windscreen to see if any water enters the cabin.
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Water pooling in nearside rear passenger footwell
    Nov 2011
    Leicester
    Thanks Andy, I will give it a go. Mick
  4. Re: Water pooling in nearside rear passenger footwell
    Nov 2011
    Leicester
    I have taken the carpet up (what an easy job!!!!!) as suggested by Andy and the whole of the nearside was full of water. All I needed was bar of soap and I could have had a bath. Found the drain pipe from the AC unit and it now has a modified outlet. The original outlet is behind the heat shield fabric and opens under the weight of water. For whatever reason mine did not open and the car filled with condensed water from the AC unit. I now have a 7 inch pipe fixed to the AC oulet sealed by the original body seal and out through the heat shield to drip onto the under engine floor tray. I have dried off the CCU but I now have the mammoth task of trying out the carpet. I will try the hosepipe opnce everything is dry.
  5. Re: Water pooling in nearside rear passenger footwell
    Jun 2007
    That A/C mod may cause a whistling/sucking noise from the condensation tray. You should perhaps gay a can of anti fungal A/C spray as that may be why the valve did not open due to mould.
    If it was that wet you have better lift the rear pasenger carpet as the water migrates backwards via the rear heater vent recess in the floor pan. Regards Peter
  6. Re: Water pooling in nearside rear passenger footwell
    Dec 2009
    southampton uk
    Dont envy you drying out this time of year if the foam under the carpet is sodden as it was on my Avant when the rear washer line popped under the carpet.Sounds a lot of water just from the aircon is the rear washer giving a full jet of water?
  1. Important Water Leak in Passenger Rear Footwell
    By Hodgy in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2014, 07:34 PM
  2. water in the rear passenger footwell!
    By sompop in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-06-2010, 06:49 PM
  3. water in passenger rear footwell
    By laxy123 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2010, 08:00 PM
  4. Water in rear passenger footwell
    By MAZI in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2008, 07:25 PM
  5. Water in rear passenger footwell
    By avantiblue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2007, 01:43 AM
