Thread: 2.7T Transmission Fluid
  1. 2.7T Transmission Fluid
    Mar 2008
    Can anyone tell me which transmission fluid I should be using for my 2.7T Quatro?
    What is the Capacity?
    How much does this stuff cost?
    The Gearbox Code from the service record is EUU FAX.
    Cheers Chapmac41
  2. Re: 2.7T Transmission Fluid
    Your best bet is to just go to audi part dept and ask them. It'll probably be the same as mine and they cost about £10 for 1 litre. Spec says 9 litre capacity but you won't get more than 7 in. Worth buying all 9 though as the ones you don't need you can take back for a refund as lang as they are not opened. If your changing the oil then i recomend an new filter and sump gasket too. You need VAGCOM to keep an eye on the temp when priming the system back up.
    Allroad 2.5 tdi BAU Tip
    A4 Avant 1.9 tdi (homebrew remap) sport
  1. Transmission Fluid
    By jonathanfenton in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-03-2010, 02:30 PM
  2. Question Transmission fluid
    By Duncstar in forum Golf MK3 - 1993 - 1999
    Last Post: 10-08-2009, 10:10 AM
  3. Which transmission fluid ?
    By brighton123 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-05-2009, 11:21 PM
  4. Automatic transmission fluid
    By cyberpor in forum Alhambra
    Last Post: 28-09-2007, 09:40 PM
  5. Transmission fluid
    By godfried in forum Audi A3 - Archive Topics
    Last Post: 04-07-2007, 04:15 PM
