Thread: difference between asz and arl engines
Results 1 to 9 of 9
Hybrid View
  1. difference between asz and arl engines
    Hi I've got a bora with a appitite for cams last one lasted 19k. Was going to replace the full engine but findinding it hard to get a arl with. A decent milage for under 1k. Was wondering if a asz would fit using my turbo and ancillaries and what's the main diffenecebetween the 2 engines
  2. Re: difference between asz and arl engines
    135 Post(s)
    2038 Post(s)
    The only physical difference between an ASZ and an ARL is the pistons which are stronger on the ARL.
  3. Re: difference between asz and arl engines
    Cheers do you think it'll run right with a 150 ecu and turbo
  4. Re: difference between asz and arl engines
    135 Post(s)
    2038 Post(s)
    The head and injectors are identical so there is no reason why not. In my opinion, ARL engines eat their cams due to the loadings placed on the oil by the turbo so just swapping the engine will not make any difference. What make of cams have you been using and which oil?
  5. Re: difference between asz and arl engines
    Its a genuine vw cam and always use vw oil. The cars completely standard the first cam went at 142k and this one 161k. Its in vw at min getting checked out on there 2 year warrenty ont the cam. Is it wort keeping the car or just get it running and part. Ex it
  6. Re: difference between asz and arl engines
    135 Post(s)
    2038 Post(s)
    It would be interesting to know if it has failed on a valve or injector eccentric.
  1. difference between the 1990's 5 cylinder engines?
    By Lettuce in forum Naturally Aspirated
    Last Post: 02-09-2010, 02:41 PM
  2. What is the difference between the 115 and 130 engines on the A6 1.9 Avant?
    By peterweedon in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-03-2009, 11:38 PM
  3. Difference between old and new 3.2 engines?
    By Space Cadet in forum Archive posts
    Last Post: 13-02-2008, 06:14 PM
  4. Difference between AFB and AKN engines?
    By Adam_W in forum Chat - Anything with wheels
    Last Post: 27-01-2008, 11:52 PM
  5. Replies: 7
    Last Post: 24-10-2007, 10:37 AM
