Thread: Bulb failure - random warnings after replacing bulbs with LEDs
  1. Bulb failure - random warnings after replacing bulbs with LEDs
    Sep 2011
    Melksham, Wiltshire, UK
    I switched my front side-lights from filament bulb to a set of CANbus error free LED lamps...seem to be OK in use, but occasionally I get a 'bulb error' on the display accompanied by a warning tone, after a short while it goes. As I say, the LEDs work fine in normal use, just on start up.
    Mines a 2007 MY A3 8P.
    Is there anything I can do to stop this from occuring?
    Many thanks.
    1999 GTi Turbo - Turbo Technics uprated turbo, Forge charge cooler, Jabba remap, Milltek SS system, Brembo GT brakes, Koni Sportlines, Neuspeed ARBs
  2. Re: Bulb failure - random warnings after replacing bulbs with LEDs
    Jan 2010
    Wakefield, West Yorkshire
    NO - unless you change back to the normal bulbs or get a new battery !!
    Canbus error free bulbs cannot be guaranteed to not show a warning. I put mine in 18 months ago and every cold(ish) morning I get an error on the nearside one. Switch off the engine and re-start and after a few seconds the warning goes out.
    My battery is pretty knackered and sometimes only shows 10.2 volts in a morning and at that voltage the current is not high enough (even with error free led's) to tell the computer that all is ok. Hence you get a warning. After starting the engine for a minute or so the battery gets a boost up to a more acceptable level and, after switching off and therefore removing the error, when you start again all becomes ok.
  3. Re: Bulb failure - random warnings after replacing bulbs with LEDs
    Sep 2011
    Thanks Mike.....I'll get the battery changed as winter prevention job this weekend, in any case, and we'll see if this does the trick!
    Thanks again for the reply.
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. Bulb failure warnig lit - all bulbs working ok ?
    By Rob69 in forum Touran - Sharan - Caravelle
    Last Post: 01-06-2011, 09:48 PM
  3. Avant rear LEDs triggering bulb out warning?
    By neebsta in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-04-2011, 10:18 AM
  4. Strange Bulb Warnings
    By jayandmaz123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2009, 07:30 PM
  5. Bulb Warnings on DIS
    By NickPicks in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-05-2009, 09:47 AM
