Thread: RNS510 retrofit in Passat CC MY2011
  1. RNS510 retrofit in Passat CC MY2011
    Jun 2011
    Málaga (Spain)
    I've already purchased a brand new RNS510 for my Passat CC MY2011 to replace the RCD510 I already have installed, and it almost works, but I cannot update the configuration in the CAN bus to tell there is a navigator as the labels for the first byte are not available in the VDCS v11.10.1. Here is the screen:
    The strange points I found are that I can access to the navigation module, and try to configure it, so it seems to have been detected and also as a different with other CAN versions, mine has only 3 bytes of coding, while others have 10bytes.
    Does anyone knows the bit I have to change to configure it in the Can bus?
    Thanks!
    PD: This is the autoscan WITHOUT the RNS connected (with the RCD510):
    Thursday,10,November,2011,22:56:06:08626
    VCDS Version: Beta 11.10.1
    Data version: 20111020
    Chassis Type: 7N0
    Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 42 44 46 47 4F 52 53 55
    56 61 62 69 72 77
    VIN: WVWZZZ3CZBE739613
    01-Engine -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    2E-Media Player 3 -- Status: Sporadic communication error 1000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Sporadic communication error 1000
    61-Battery Regul. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
    Part No SW: 06J 906 027 L HW: 06J 907 309 B
    Component: MED17.5.2 03 8318
    Revision: PAH04--- Serial number: VWZCZ000000000
    Coding: 0404000C18070160
    Shop #: WSC 05314 000 00000
    VCID: 346D133C5720751
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 3AA-614-109.clb
    Part No SW: 3AA 614 109 N HW: 3AA 614 109 N
    Component: J104 C2 450M VDEE 0005
    Revision: --H07--- Serial number: 00000003514144
    Coding: 0001414
    Shop #: WSC 05311 000 00000
    VCID: 3875270C4B48911
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
    Component: Climatronic H17 1010
    Revision: 00003001
    Coding: 0000000002
    Shop #: WSC 00015 115 00000
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_Climatronic_VW46.rod
    VCID: 6ED9C154B18C1F1
    Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
    Part No SW: 3AA 937 087 A HW: 3AA 937 087 A
    Component: BCM PQ47 H 413 0452
    Revision: BB413001
    Coding: 000000000000000000180210B4000BA44755768861600D6064 8846200041
    Shop #: WSC 05311 123 12345
    VCID: 3875270C8B48911
    Subsystem 1 - Part No SW: 3C8 955 119 D HW: 3C8 955 119 D
    Component: Wischer 03111 10 0603
    Coding: 00B795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 261110 05 54 0403
    Coding: 0730ED
    Address 10: Park/Steer Assist (J446) Labels: None
    Part No SW: 3AE 919 475 HW: 7N0 919 475
    Component: PARKHILFE 8K H04 0009
    Revision: -------- Serial number: 77631033502473
    Coding: 118003
    Shop #: WSC 99999 1023 2097151
    ASAM Dataset: EV_EPHVA18VW47X0000 001003
    ROD: EV_EPHVA18VW47X0000.rod
    VCID: FCFD7B1C77F0FD1
    Address 14: Susp. Elect. (J250) Labels: None
    Part No SW: 3C0 907 376 A HW: 3C0 907 376
    Component: DAEMPFUNGS-SG H07 0071
    Revision: 00000000 Serial number: 01121002850001
    Coding: 010180
    VCID: 2757F47056F60E9
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
    Component: J234__305 VW10 HI 1918
    Revision: 22014000 Serial number: 003K0PPEE4J
    Coding: 0012341
    VCID: 4C9D6BDC2FD00D1
    Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
    Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
    Component: LENKS.MODUL 009 0136
    Revision: FF010039 Serial number: 20101120100452
    Coding: 0182270000
    ASAM Dataset: EV_VW360SteerWheelUDS A03004
    ROD: EV_VW360SteerWheelUDS_VW46.rod
    VCID: 72E1D524A5B43B1
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
    Component: E221__MFL-TK6 H06 0022
    Coding: E20000
    Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
    Part No SW: 3C8 920 880 H HW: 3C8 920 880 H
    Component: KOMBI H02 0207
    Serial number: 00000000000000
    Coding: 140F01
    Shop #: WSC 05314 115 00000
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
    VCID: 31631A286032409
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 G HW: 1K0 907 951
    Component: J533 Gateway H41 1614
    Revision: H41 Serial number: 051210F2001976
    Coding: 469006
    VCID: 346D133C9720751
    3 Faults Found:
    01304 - Radio
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 22
    Mileage: 14164 km
    Time Indication: 0
    Date: 2010.14.14
    Time: 19:22:43
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 7
    Mileage: 14164 km
    Time Indication: 0
    Date: 2010.14.14
    Time: 19:25:48
    03272 - Control Module for Audio Interface
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 22
    Mileage: 14164 km
    Time Indication: 0
    Date: 2010.14.14
    Time: 19:22:43
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3AA 959 433 HW: 3AA 959 433
    Component: IMMO 043 0399
    Revision: 00043000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: F6E9693481DCA71
    Part No: 3C0 905 861 J
    Component: ELV 029 0380
    3C0905861J ELV 029 0380
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
    Component: SG EXT.PLAYER H13 0150
    Revision: A1001003 Serial number: 7668972390
    Coding: 010000
    VCID: 2855F74C5BE8011
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C8 959 701 HW: 3C0 959 793 C
    Component: TUER-SG FT 002 0501
    Revision: 12110009 Serial number: 0001814104
    Coding: 0010B7
    Shop #: WSC 05311 115 00000
    ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
    ROD: EV_TSGFPQ35BRFVW46X.rod
    VCID: EDDB46583C8A649
    Slave Driver:
    Subsystem 1 - Part No SW: 3C8 959 703 C HW: 3C0 959 795 B Labels: 3C0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 004 0401
    Serial number: 00000001754943
    Coding: 000090
    Address 44: Steering Assist Labels: 5N1-909-144.clb
    Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
    Component: J500__APA-BS KL.297 0802
    Revision: 1AH03729 Serial number: 00103300224101
    Coding: 0000258
    VCID: 3B7F38007A7EBA9
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ47 ELV 043 0631
    Coding: 00910A0001864E763602941570084FCE707C01
    Part No: 1K8 951 605 A
    Component: LIN BACKUP HORN H11 9004
    Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Component: Innenraumueberw.004 0611
    Address 47: Sound System Labels: 3C0-035-456.lbl
    Part No SW: 3C8 035 456 C HW: 3C8 035 456 C
    Component: DSP 10 Kanal 0070
    Revision: 00H06001 Serial number: 75805002592307
    Shop #: WSC 03499 574 72460
    VCID: 2855F74C9BE8011
    Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 1K0 907 951
    Component: EZE_2 H41 1614
    Coding: 00000008
    VCID: EFE75C503E86969
    Subsystem 1 - Part No SW: 3AA 919 204 HW: 3AA 919 204
    Component: Analoguhr 003 0003
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C8 959 702 HW: 3C0 959 792 C
    Component: TUER-SG BT 002 0501
    Revision: 14110009 Serial number: 0001810558
    Coding: 0010B6
    ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
    ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
    VCID: EED94154318C9F1
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B Labels: 3C0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 004 0401
    Serial number: 00000001740764
    Coding: 000090
    Address 53: Parking Brake Labels: 3AA-907-801.clb
    Part No SW: 3AA 907 801 E HW: 3AA 907 801 D
    Component: J540 EPB4 VW-55183 0007
    Revision: H18 Serial number: 00000000120065
    Coding: 0022057
    VCID: 336F1020522E729
    Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0148
    Revision: 00H04000 Serial number:
    Coding: 3493064
    Subsystem 1 - Part No: 1K0 941 329
    Component: AFS-Lst.-Modul l 0008
    Coding: 00000053
    Subsystem 2 - Part No: 1K0 941 329
    Component: AFS-Lst.-Modul r 0008
    Coding: 00000053
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 HW: 3C8 035 195
    Component: Radio RCD510 041 0166
    Revision: 00000001 Serial number: VWZ1Z3K6414887
    Coding: 0101000001
    VCID: E5CB3E78EC7A5C9
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H41 1614
    Coding: 03220858
    VCID: F1E35A2828B2809
    Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
    Component: J367-BDM H07 0150
    Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: Anhaenger H07 0100
    Revision: 3A001001 Serial number: 00000137836559
    Coding: 410D000100000000
    VCID: 30651F2C6338491
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 B HW: 7P6 035 730 B
    Component: TELEFON H05 0440
    Revision: 1B001001 Serial number: 00007668996726
    Coding: 0A01000000010101
    ASAM Dataset: UHVNA A01007
    ROD: UHVNA_VW46.rod
  2. Re: RNS510 retrofit in Passat CC MY2011
    Jul 2008
    Coventry
  3. Re: RNS510 retrofit in Passat CC MY2011
    Jun 2011
    Málaga (Spain)
    Thanks a lot Hartry!. I activated it from the list and solve the problem.
    No errors now,
    Regards,
  1. Footwell lights activation in Passat CC MY2011
    By passatcc20tsi in forum VCDS - Help Requests
    Last Post: 25-10-2011, 06:24 AM
  2. Replies: 0
    Last Post: 21-07-2011, 02:46 PM
  3. Question retrofit MFD2 in early passat?
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-02-2011, 05:31 PM
  4. RNS510 or aftermarket RNS510 which one is better?
    By j32maniac in forum In Car Entertainment
    Last Post: 21-11-2009, 04:25 AM
  5. Installing RNS510 in a 08 Passat Sport Estate
    By joost in forum In Car Entertainment
    Last Post: 07-09-2008, 10:36 AM
