Thread: canbus on golf mark 6
  1. canbus on golf mark 6
    Feb 2010
    kilwinning ,ayrshire
    HI ALL, i HAVE JUST PURCHASED A NEW DETACHABLE TOWBAR WHICH I HAVE FITTED TO MY VW GOLF MARK 6 2L GT. THIS WAS A DREAM TO FIT AND EVERYTHING WENT LIKE CLOCKWORK UNTIL I HAD A LOOK AT THE BYPASS SYSTEM.I HAVE IN THE PAST FITTED ELECTRICS TO MANY CARS BUT THIS IS THE FIRST WITH THE CANBUS AND RELAY WHICH WAS SUPPLIED WITH THE TOWBAR, THE BYPASS IS A PCW UNIT AND CAME WITH FULL INSTRUCTIONS, I CAN FOLLOW THE WIRING TO THE TOWBAR SOCKET BUT AM UNSURE WHAT WIRE COLOURS TO CONECT FOR THE BRAKE , SIDE LIGHTS INDICATORS ECTIN THE CAR, ALSO I SEE IN ANOTHER POST SOMEONE USED THE SCOCKET IN THE BOOT AND TAPPED INTO THE LIVE SIDE OF THE SOCKET WITH AN INLINE FUSE TO PROTECT THE UNIT.
    I AM LOOKING FOR SOMEONE WHO HAS CONECTED A BYPASS SYSTEM TO THERE GOLF AND ANY FEEDBACK ON THE POWER SUPPLY ETHER FROM FUSE BOX OR IS IT SAFE TO USE THE SOCKET IN THE BOOT AND WHICH WIRES TO CONECT THE SCOTCH LOCKS TO ON THE CARS WIRING LOOM . MANY THANKS JOHN.
  2. Re: canbus on golf mark 6
    Norfolk
    Try these.
    The best thing is to test one circuit first using an LED circuit tester
    (not one with a bulb in it)
    Rear left fog light bulb grey/white
    Rear right fog light bulbgrey/white
    Right tail light bulb grey/yellow
    Left tail light bulb grey/black
    Rear left turn signal bulb black/white
    Rear right turn signal bulb black/green
    Left reversing light bulb Black/blue
    Right reversing light bulb Black/blue
    Left brake and tail light bulb black/red
    Right brake and tail light bulb black/purple
    Some of these wires become plain black after the last connector,
    so to see the original colour code wires you may have to remove the trim to
    find them. That’s why a circuit tester helps. Saves removing so much trim.
  3. Re: canbus on golf mark 6
    Feb 2010
    Hi martin, Many thanks for your info , do you know if I can take a feed from the socket which is in the boot to power up the bypass unit instead of using the supply from the fuse box.
    John.
  4. Re: canbus on golf mark 6
    Norfolk
    Yes you can use the rear power socket as the power supply. It might be an idea to add an inline fuse just in case, although the socket is fused anyway.
  5. Re: canbus on golf mark 6
    Mar 2009
    Manchester, England
    John do not use the socket in the boot this is ignition feed & the bypass needs to a permanant live FUSED, you will need to pick up from the fusebox.
    Brian
    PF Jones Towbars | National Mobile Towbar Fitting | Audi Towbars
    We will beat any like for like price on all Witter and Westfalia Towbars 0161 872 4755
  6. Re: canbus on golf mark 6
    Feb 2010
    Hi PF Jones, Many thanks for your reply about the power supply from the socket in the boot, I thought this was live at all times.
    I have looked at the fusebox at the side of my dash and cannot find a permanant live with my meter ?
    Any ideas where it would be on this car or have i just missed it.
    Many thanks again.
    John.
  1. Question Mark 5 & Mark 6 Golf
    By John@kingsleyro in forum New Member Introductions
    Last Post: 01-09-2009, 08:25 AM
  2. golf mark 4 problems
    By c_j in forum Golf MK4 - 1999 - 2004
    Last Post: 16-08-2009, 07:04 PM
  3. Please Help Is it possible to remap a 1.4 mark 4 golf
    By Awais in forum Golf MK4 - 1999 - 2004
    Last Post: 30-07-2009, 02:38 PM
  4. Servicing a VW GOLF MARK IV
    By Golf_TDI in forum Chat - Anything with wheels
    Last Post: 28-09-2008, 03:37 PM
  5. Mark IV Golf
    By shahid1973 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-07-2007, 12:32 PM
