Thread: Newbie Manual Gearbox Help Please
  1. Newbie Manual Gearbox Help Please
    Aug 2008
    Somerset
    Hi guys
    Just brought a 2004 saloon for not alot
    My Engine is a 1.9tdi 130 AVF and my Gearbox is a GVS
    I have a couple of gearbox related questions if I may,
    1) Previous owner drove the car with their hand resting on the gear knob and as a result the knob rattles. Anyone with any idea what parts to replace to shut it up ?
    2) There is a whine coming from the box when the car is in gear. Load makes no difference to the noise. My question is any idea whats causing this noise ?
    Thanks in advance.
  2. Re: Newbie Manual Gearbox Help Please
    Mar 2010
    Lincolnshire
    Quote Originally Posted by dulux72 View Post
    Hi guys
    Thanks in advance.
    Hi there - Glad you bought for not a lot...... I hate to be the bearer of bad news but if gearbox whining it'll be the bearings in the gearbox - I had same problem and had two bearing replaced - Cost £650 quid just to recon the box (6 speed are prone to this), that was on top of the bill to remove the box - I had new drive shafts, dual mass and cluth at same time along with an oil service and cost around 2k - sorry - I hope your's isnt this!!!!
  3. Re: Newbie Manual Gearbox Help Please
    Aug 2008
    Somerset
    Thanks for the reply.
    I don't suppose that they stated what bearings they replaced.
    I 'll take the box out myself and recon the box just need to know what bearings will be the cause
  4. Re: Newbie Manual Gearbox Help Please
    Mar 2010
    Lincolnshire
    Pinion bearings, I'm sure - Make sure do them both as useless <removed> that did mine only did one and it had to go back in - Was sweet after that - Good luck, but get a professional answer first
    Last edited by Guest 2; 06-11-2011 at 11:44 PM. Reason: Swear filter is in place for a reason, don't bypass it by using *'s please.
  1. Manual Gearbox Oil Change
    By Northsea in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-09-2011, 09:51 PM
  2. Question T4 2.5TDI manual gearbox swop
    By adzul in forum The Commercial Range
    Last Post: 21-11-2009, 09:09 PM
  3. Please Help Problem with manual gearbox.
    By Tinkerbelle77 in forum Audi A3 - Archive Topics
    Last Post: 20-08-2008, 09:32 PM
  4. How To t4 auto to manual gearbox?
    By steamie in forum Touran - Sharan - Caravelle
    Last Post: 09-08-2008, 01:36 PM
  5. manual gearbox identification
    By aniesigh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-06-2008, 12:13 AM
