Thread: VW 1997 2.0L GTI engine running problem
  1. Angry GOLF MK3 1997 2.0L GTI engine running problem
    May 2006
    Hi, I'm new to this website so please treat me gentley.
    I have just purchased a 2.0L GTI which has done approx 100,000 miles.
    I have a couple of problems which are hard to explain :-
    i) With a cold engine, it starts first time no problem, but during driving when accelerating it feels like the engine is holding back also may have very slight judder.
    ii) When the engines is warm or hot, on accelerating through the gears it still feels as if it is holding back but not anywhere near as bad as when cold.
    I have serviced the following parts on the car, plugs, aircleaner, fuel filter, oil, oil filiter, cleaned inside distributor cap and rotor.
    Hope you can help
    Mike.
  2. lambda sensor
    I think you will find it is your lambda sensor on your exhaust by your cat that is causing the problem i had the same problem and it is solved now i have a new one hope this helps
  1. indicator failure whilst engine is running
    By rian p in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2015, 03:26 PM
  2. 1.4L 1997 Polo - engine cut out
    By MikeJBro in forum Polo - Derby - Lupo - Fox
    Last Post: 21-05-2007, 11:18 AM
  3. Engine Running Hot
    By Hynes in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-05-2007, 12:53 PM
  4. 1997 golf 1.9TD GL overheating problem
    By wyndym in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-01-2007, 03:23 PM
  5. golf mark 4 engine running problem
    By tyce in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-10-2006, 08:41 PM
