Thread: VW FOX 1.2 Heater not working. Any ideas?
  1. VW FOX 1.2 Heater not working. Any ideas?
    Blairgowrie
    Hi guys, ive got an 07 plate 1.2 Fox with roughly 56k on it. The heater is just blowing cold air! when i turn it to hot the air is slighly different in flow indicating the flap is working but no hot air with unfortunately.
    Any suggestions would be greatly appreciated as i cant afford to take it to the ********
    03 Octavia 1.9tdi ALH, EGR Off, 150k, Ambiente, no aircon even though there is a switch
  2. Re: VW FOX 1.2 Heater not working. Any ideas?
    Aug 2007
    Newport, Wales
    7 Post(s)
    I'm not sure if the Fox uses old-school cable opperated heater controls or if it's electronic?
    If electronic; it could be a problem with the motorised flap which directs the air from the blower towards -or- away from the heater matrix (the radiator that has hot engine coolant flowing through it). Sometimes the motors get stuck or turn beyond their intended stopping point and need manually turning back.
    You could tackle this in one of two ways..
    1. Use VAG Com to read fault codes and see if any are listed for central convenience - hopefuly it will identify the exact motor if there's a fault code.
    2. If you don't have Vag-Com, take the glovebox out which should give you access to most of the motors which control the heater matrix flaps. By a proccess of elimination, use the buttons / dials on your heater controls to see what each motor does (sometimes they are colour coded in groups to help you identify whether they control heat selection or which vents the air comes out of).
    I suppose the other possibility is that the heater matrix isn't getting hot, does the coolant temparature get upto 90c nice and quickly and stay there or does it fluctuate?
    Al
    I hope for your sake it's not a faulty heater matrix.. because changing it is an ugly job... it took me about 8 hours to do it on my Mk3 VR6 Golf:
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  3. Re: VW FOX 1.2 Heater not working. Any ideas?
    Nov 2009
    Bristol
    Hmm, could be the heater matrix is blocked.
    2002 Polo 9n 1.2 65PS. Basic but it's better than the train!
  1. Engine Pre-heater Ideas please.
    By Lofty79 in forum Chat - Anything with wheels
    Last Post: 29-11-2012, 02:46 AM
  2. Heater controls flashing any ideas
    By Roo65 in forum Touran - Sharan - Caravelle
    Last Post: 27-11-2010, 02:10 PM
  3. 2008 VW Fox - Wipers not working
    By tiptop in forum Polo - Derby - Lupo - Fox
    Last Post: 20-12-2009, 07:07 PM
  4. Please Help Electric sunroof not working,any ideas?
    By Hurley1611 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-05-2009, 12:50 AM
  5. Fox RDC 200 Fader Not Working
    By Laurie-Boi in forum Polo - Derby - Lupo - Fox
    Last Post: 20-02-2008, 05:47 PM
