Thread: Polo 1.4 Auto power-loss / stalling when accelerating
  1. Question SOLVED: Polo 1.4 Auto power-loss / stalling when accelerating
    Aug 2007
    Newport, Wales
    7 Post(s)
    All of a sudden, my 1998 Polo 1.4 Auto is suffering power-loss, cutting-out or even stalling when I accelerate.
    I've noticed that the car struggles to move and the revs drop when I press the accelerator when the engine is idling. When the car is stood still with the auto box in D (drive) with my foot on the brake pedal; the car will randomly try to lurch forward a bit every 4-5 seconds as if I'm pressing the accelerator pedal (but obviously I'm not!)
    My initial thoughts were brake pedal switch.. but reading up on various forums, people suggest the idle stabilisation valve and cleaning out the throttle body.
    I will try the above but if anybody could chuck their experience / opinion in, it'd be much appreciated.
    Al.
    PS: About 2 weeks ago I had the cam belt and water pump changed. It wouldn't suprise me if the garage had spilt coolant over a sensor somewhere and it's taken a while to work it's wayinto the electronics!
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  2. Re: Polo 1.4 Auto power-loss / stalling when accelerating
    Aug 2007
    Newport, Wales
    7 Post(s)
    I cleaned the throtle body (using this guide) and replaced the 4-pin temp sender and it appears to have sorted it. I've been out for a few drives in it and it hasn't missed a beat. I won't feel 100% confident I've got it licked until I've driven the car without issue for at least a week!
    I also discovered that the small pipe that's attached to the throttle body goes off to some form of valve which in turn is connected to what looks like a charcoal filter unit (in the front of the driver's side wing). The charcoal filter unit was just hanging loose on it's side.
    I re-mounted this vertically as it should be. I wonder if this is something the garage displaced when they were changing the cambelt?! As this pipe effectively helps feed air to the engine when the throttle body butterfly is closed, I'm wondering if the charcoal filter malfunctions if placed on it's side, not allowing any air through?
    Al.
    Credit for photos: M60_maniac of ClubPolo.co.uk
    [ Past Audis:
    A6 S-Line 3.0
  1. Polo auto stalling
    By George Damper in forum Polo - Derby - Lupo - Fox
    Last Post: 06-11-2011, 07:40 AM
  2. Please Help Golf 3 GTI 2.0 ADY intermittent Power loss and stalling, please help.
    By pmartin13 in forum Golf MK3 - 1993 - 1999
    Last Post: 01-07-2011, 08:58 AM
  3. Please Help Golf 1.6 Auto random power loss
    By Aodhan in forum Golf MK5 - 2004 - 2009
    Last Post: 09-06-2010, 05:55 PM
  4. Please Help golf 1.8 auto loss of power when warm
    By ryngrm in forum Golf MK3 - 1993 - 1999
    Last Post: 21-07-2009, 05:20 PM
  5. Power loss at 1200 RPM with intermittent stalling and ESP dash warning
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2008, 08:18 PM
