Thread: Q7 Battery Drain issue - Help Please
Page 4 of 4 FirstFirst ... 234
Results 31 to 32 of 32
  1. Re: Q7 Battery Drain issue - Help Please
    #31
    Feb 2016
    sydney
    Im having the same issue in my 2009 q7, stuck in a carpark now waiting for it to turn on. Had a major service done recently with no issues except a faulty dpf sensor which we changed. After trying to start it theres a whurring noise in mid left, then it turns off after a few minutes.
  2. Re: Q7 Battery Drain issue - Help Please
    #32
    Sep 2007
    I had several 'symptoms' that were cured when I changed the battery. Not cheap since the battery has to be coded in to the system - else things don't work. Interesting my '13 plate battery isn't holding a charge too well at the mo. Put it on battery charger for 24 hours all OK - then check a day later - 20%. There must be a lot of drain on the battery - or it's buggered - again.
  1. RNS 510 battery drain issue - solved?
    By tdi sport in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-12-2012, 06:45 PM
  2. Another battery drain issue
    By limecc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2011, 10:47 PM
  3. battery drain
    By debjohn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-03-2010, 12:21 AM
  4. MkII Golf ECU/purge valve issue - causing battery drain
    By BillyNoMates in forum Archive posts
    Last Post: 17-01-2008, 03:03 PM
  5. Another battery drain issue
    By g7kse in forum Golf MK5 - 2004 - 2009
    Last Post: 09-01-2008, 03:38 PM
