Thread: battery drain plug
  1. battery drain plug
    Apr 2007
    Help. I've had the usual water ingress problem with the pollen filter housing and have managed to find the drain plug under the battery and battery plate and air con hoses. After 30 minutes of swearing and cut and battered hands managed to unblock the hole. Someone please tell me there is an easier way. Or do i have to take the wipers, off then the plastic cover then the battery out. Even then i cannot see the hole? What would happen if i removed the rubber bung and left a great big hole instead?
  2. Re: battery drain plug
    May 2006
    Crap design, remove bung completely, nothing adverse will happen except not getting blocked and allowing water to drain.....
  3. Re: battery drain plug
    Apr 2007
    Thanks for the reassurance of removing the plug completely. Shall remove at the weekend.
  4. Re: battery drain plug
    Oct 2005
    I've read posts on people removing from underneath the car - you may (or may not) want to try that way.
  1. battery drain
    By jasey1007 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2008, 08:29 PM
  2. battery tray drain plug.......
    By rs4 in forum Audi A4 - Archive Topics
    Last Post: 26-05-2007, 06:48 AM
  3. Battery drain
    By nickasaki in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2006, 01:51 PM
  4. Passat Battery drain
    By Blobnose in forum Passat - Archive Topics
    Last Post: 20-09-2006, 05:44 PM
  5. A3 Tdi Battery drain mystery!
    By moreski in forum Audi A3 - Archive Topics
    Last Post: 05-03-2006, 10:29 AM
