Thread: 2001 face lift rear lights
  1. Question 2001 face lift rear lights
    Apr 2007
    Suffolk
    Will the 2000 face lift rear lights fit on 96 (saloon) ?
    Are the plugs or wiring different ?
    The orange rear indicators just don't go with a black car.
  2. Re: 2001 face lift rear lights
    norn iron
    yes they do,i have done this.all u have to do is swap the indicator and reverse lights over.ie cut the main feed to the bulb holder and swop around.its dead easy.ill have a look 2morrow and tell ya wot wires to cut and join
  3. Re: 2001 face lift rear lights
    paul20v Guest
    Quote Originally Posted by stubbsy View Post
    aaagh dont cut them the wires come out of the plugs pull out the retaining clip and there is a little metal clip in the plug which is part of the connecter lift it up with a needle or similar and swap them over you can trace the wires on the bulb holder buy seein which one you want to light up but >96 bulb holder are different they have a separate side light you need bulb holders 98 on but they are cheap even from dealers
    cheers
  4. Re: 2001 face lift rear lights
    norn iron
    unless its a really early a4 paul is correct,the ones that ahave the small reverse lights.my wifes car is 96 and has these
  5. Re: 2001 face lift rear lights
    norn iron
    my 98 model had the same as the wifes,i changed these to the 99 model on. bulb holders where the same.wireing colours that need to be swopped round are, black/green and blue/red
  6. Re: 2001 face lift rear lights
    norn iron
    the early ones look something like these but im sure theres another version of these as well,same sort of layout.
  1. 2.5TDi Needle Lift Sensor
    By SimonBbk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-01-2009, 01:23 AM
  2. a4 1999-2000 face lift
    By ajay in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-06-2007, 12:27 PM
  3. rear lights
    By tweeky in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-03-2007, 05:06 PM
  4. 2001 S6 - Rear facing seats - to be or not to be?
    By juliangranville in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-03-2007, 11:38 AM
  5. 2001 1.5 passat - warning lights
    By jomcl in forum Passat - Archive Topics
    Last Post: 23-08-2006, 09:05 AM
