Thread: 12v at ignition switch but nothing at starter solenoid.........
Results 1 to 10 of 11
  1. 12v at ignition switch but nothing at starter solenoid.........
    i've measured 12v at the ignition switch (red/black wire) while trying to crank but nothing at the trigger wire on the starter solenoid.
    i think this wire goes directly there (apart from the immobiliser?) so is this the only place to investigate?
    are there any fuses or relays involved?
    thanks
  2. Re: 12v at ignition switch but nothing at starter solenoid.........
    from the ignition switch the wire enters the rear of the fuse box terminal H/1 and exits terminal F/1 before going to the starter,no fuses no relays if we are talking manual gearbox
  3. Re: 12v at ignition switch but nothing at starter solenoid.........
    131 Post(s)
    1976 Post(s)
    That's spooky Kenney, that is almost exactly the same as my post for this chap on another forum altogether!
  4. Re: 12v at ignition switch but nothing at starter solenoid.........
    great minds think alike and fools seldom differ and it is hallowen
  5. Re: 12v at ignition switch but nothing at starter solenoid.........
    i've found the wire down near the fusebox but doesnt appear to have any involvement with the fusebox due to the wire being spliced to a black wire running to the immobiliser??
    i've checked where the wires are joined and have 12v there while trying to crank
    i can't get to to where the control box is as access is very restricted!
  6. Re: 12v at ignition switch but nothing at starter solenoid.........
    131 Post(s)
    1976 Post(s)
    Find the other end of the splice and join it back together, it sounds like the immobiliser has failed.
  7. Re: 12v at ignition switch but nothing at starter solenoid.........
    the starter solenoid has a direct power source from the ignition switch the wire in question as stated before enters and exits the fuse box,the immobiliser has nothing to do with the starter unless it is an aftermarket unit ?
  8. Re: 12v at ignition switch but nothing at starter solenoid.........
    i'll have a root around for it...
    presumeably it will be coming out of the immobiliser control unit somewhere?
    this is probably a stupid question...but it there are no fuses/relays associated with this wire why does it go to the fuse board??
  9. Re: 12v at ignition switch but nothing at starter solenoid.........
    Quote Originally Posted by kenney View Post
    yes sorry i'm talking about an aftermarket immb. not the ff one.
  10. Re: 12v at ignition switch but nothing at starter solenoid.........
    Quote Originally Posted by hornetcarp View Post
    that explains it then,the fuse box is a connecting point for most of the wiring,no other reason,and the question is, does the vehicle have an original immo too??????,if that is the case then it is probably an after market alarm that has been fitted which is the problem,these alarms are often connected to starter solenoid
  1. Starter Solenoid Problem?
    By jasper0407 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-02-2010, 03:17 PM
  2. Please Help Ignition Starter Switch
    By Rammer in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-09-2009, 06:31 PM
  3. Starter Motor Solenoid
    By DOUGtdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-10-2008, 01:21 PM
  4. Ignition switch/barrel and starter motor
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-01-2008, 08:25 AM
  5. Ignition Switch does not engage Starter
    By massauto in forum Golf MK3 - 1993 - 1999
    Last Post: 21-10-2007, 09:36 AM
