Thread: Whosh noise and then no power! Now can't drive without kangaroo motion and smoke!
  1. Whosh noise and then no power! Now can't drive without kangaroo motion and smoke!
    Sep 2008
    Shetland, Scotland
    Audi A3 Sportback TDI 140, 05 plate 65k miles/ well looked after and good condition.
    With no prior warning of lights etc, driving gently up a hill changing into 3rd gear, a whoosh noise of either air or fluid occurs. Shortly after power is much less and it can't get beyond 1st gear without missing and hiccuping like its about to stall - but doesn't. Stopped car immediately but no warning lights have come on either.
    As car was stopped outside a friends's garage, we wheeled into his car lift to look under - no sign of anything untowards such as fluid spills etc.
    There is a whirring noise that rises as you rev the engine, and there is a distinct increase in smoke from exhaust. The friend's thoughts are it might be the turbo blown or alternator. Waiting for trasport to a garage on Monday with hope that it's not TOO expensive a problem!!
    We did find that is was very low on oil (and have topped it up) despite no oil waring light coming on as it usually does before a top up.
    Any suggestions??
    cheers
  2. Re: Whosh noise and then no power! Now can't drive without kangaroo motion and smoke!
    one of the turbo hoses has split
  3. Re: Whosh noise and then no power! Now can't drive without kangaroo motion and smoke!
    Sep 2008
    Shetland, Scotland
    Hi, if this is the problem, with my very limited knowledge....is this easy or expensive to fix generally?
  4. Re: Whosh noise and then no power! Now can't drive without kangaroo motion and smoke!
    easy and not very expensive
  5. Re: Whosh noise and then no power! Now can't drive without kangaroo motion and smoke!
    Sep 2008
    Shetland, Scotland
    Car back from the garage today - apparently a disconnected intercooler tube ( which I think may be same as what you reckoned?) In any case a temp fix is in place until a new hose arrives for fitting. Thanks for the advice.
  1. drive shaft noise
    By oldskoolcool in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 15-11-2010, 09:03 AM
  2. A4 B6 1.9TDi 130 - Smoke and No power with rushing air noise - split intercooler
    By rkthornley in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-05-2010, 03:34 PM
  3. Drive belt noise
    By neileg in forum Golf MK3 - 1993 - 1999
    Last Post: 04-02-2008, 10:10 PM
  4. Loss of Power, Smoke and Whooshing Noise
    By MikeA4tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-11-2007, 07:49 PM
  5. passat 2.8 4 motion-strange noise
    By willyb in forum Passat - Archive Topics
    Last Post: 08-08-2006, 08:55 PM
