Thread: Parking brake problems
Results 1 to 10 of 17
  1. Parking brake problems
    Feb 2009
    Cork,Ireland
    Hi all
    Looking for a bit of help here. Her indoors told me that parking brake error came up on the mfd this morning. I hadn't experienced it myself but just did a scan anyway. Has anyone experienced this or have any ideas what the scan results indicate. Its a 2008 2.0tdi cr. There doesn't appear to be any other issues. The scan results are below. Thanks in advance.
    Address 53: Parking Brake Labels: 5N0-907-801.lbl
    Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
    Component: J540 EPB3 VW-10498 0003
    Revision: 009 Serial number: 00000000169997
    Coding: 0000057
    Shop #: WSC 00594 941 76527
    VCID: 28540557E268
    3 Faults Found:
    03200 - Switch for Electric Parking Brake (E538)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 136
    Mileage: 72989 km
    Time Indication: 0
    Date: 2011.10.06
    Time: 08:00:31
    Freeze Frame:
    Voltage: 13.30 V
    Count: 10
    Speed: 0.0 km/h
    Hex Value: 0x1170
    Hex Value: 0x0008
    Hex Value: 0x0101
    16366 - Control Module - Internal Malfunction; CPU 2
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 74292 km
    Time Indication: 0
    Date: 2011.10.28
    Time: 08:44:52
    Freeze Frame:
    Voltage: 12.20 V
    Count: 41
    Speed: 0.0 km/h
    Hex Value: 0x1271
    Hex Value: 0x0021
    Hex Value: 0x1010
    16352 - Control Module - Electrical Error
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 10
    Reset counter: 139
    Mileage: 72989 km
    Time Indication: 0
    Date: 2011.10.06
    Time: 08:00:31
    Freeze Frame:
    Voltage: 13.30 V
    Count: 42
    Speed: 0.0 km/h
    Hex Value: 0x1160
    Hex Value: 0x0008
    Hex Value: 0x0101
  2. Re: Parking brake problems
    Norfolk
    Clear the errors, wait a few days and scan again, see if anything comes back. You may have a faulty switch or it may just be an odd error. These can occur when the system gets confused.
  3. Re: Parking brake problems
    Feb 2009
    Cork,Ireland
    Thanks Martin, will do.
  4. Re: Parking brake problems
    Feb 2010
    Leamington Spa
    I had a simlar experience but in mine the park brake would not switch off. I was at a fuel station and it was embarresing! I disconnected the battery, waited 10 secs and reconnected. The park brake switch functioned OK.
    I carried out a scan when I got home and the DTC for park brake failure was live. I subsequentely replaced the switch, cleared the DTC and had no more problems. I understand that the switches have been the source of a few problems as my dealer had some in stock. Good luck.
  5. Re: Parking brake problems
    Sep 2011
    Orpington Kent
    is there a lot involved in replacing the epb switch? how do you remove it and the trim around it, thanks.
  6. Re: Parking brake problems
    Apr 2010
    Ashford, Middlesex
    Quote Originally Posted by monzo24 View Post
    Dead easy - ignition off, key out, open the drivers door, and on the side of the dashboard there is a removable plastic panel - pop it off (it only clips on) to open up the side of the dashboard, and you will see the wires going into the wiring plug at the back of the switch. Simply push the switch from behind so it pops out the front of the dash, which will then give you access to the plug; there is a small locking tab which needs to be popped up to allow the plug to be unplugged.
    And to steal a phrase from good old Haynes manuals - fitting is the reverse of removal.
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  1. ABS, Parking Brake, Squeeking brakes and brake lights!
    By medvwb6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2011, 05:35 PM
  2. Parking Brake
    By DouglasB6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2009, 05:05 PM
  3. Please Help Parking Brake
    By ncsuresh in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-04-2009, 08:51 AM
  4. A6 Parking brake problems (2005)
    By bbability in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-04-2008, 01:39 PM
  5. B6 Parking Brake ?
    By Roy in forum Passat - Archive Topics
    Last Post: 21-08-2006, 07:26 AM
