Thread: Passenger door won't open from the outside?
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
  1. Passenger door won't open from the outside?
    Jul 2008
    Bristol
    As above,
    Getting very annoyed with the door not opening from the outside. I have slammed the door hard loads of times but did not work.
    Any suggestions?
    For Sale: VW Passat 2.0 TDI Sport
  2. Re: Passenger door won't open from the outside?
    135 Post(s)
    2026 Post(s)
    Lock unit failure, a very common problem on the 3C Passat, we do a lot of them.
  3. Re: Passenger door won't open from the outside?
    Norfolk
    Quite often the cable has come off. Do a search on here, there is a fix that costs next to nothing. Just a few minutes with a drill and cable tie.
    2 0 0
  4. Re: Passenger door won't open from the outside?
    Oct 2011
    Pangbourne
    My passenger door wouldn't open from the outside and there was little/no resistance when pulling on the door handle.
    Prompted by this thread, I did a bit of googl'ing which led me to opening the window so I could work the indoor and outdoor handles at the same time. After a few minutes of opening/closing and pulling handles I heard a clunk and the outside handle now works, brilliant!
    Jul 2008
    Bristol
    Thanks guys for the quick response. Crasher, that has made me panic. I will search the thread Martin1810, and Andrew I will have another go tomorrow.
  6. Re: Passenger door won't open from the outside?
    Oct 2011
    Pangbourne
    Zeb, I just wanted to add that I was about to give up when I got that 'clunk' and it started working (very satisfying when it happened! ). I didn't spend very long working the handles together and opening/shutting the door, perhaps 2-3mins. The reason I was about to give up was because I didn't think that anything I was doing was making any difference and I couldn't think of anything 'extra' to do - it seemed futile I guess! Stick at it!
    Jul 2008
    Bristol
    I will give it a go, and hopefully the door will come back to it's senses.
    Once I open the door from the inside, it goes back to normal.
    When I lock/unlock the second time, the door opens from the outside??? Very confusing.
  8. Re: Passenger door won't open from the outside?
    135 Post(s)
    2026 Post(s)
    Quote Originally Posted by Zeb View Post
    Why? It is no big deal, it is not as if you oil pump drive has failed is it!
  9. Re: Passenger door won't open from the outside?
    Jan 2009
    we have had the same thing for 10 years or so its when someone tries opening the door when it locked the central locking gets all confused, I tend to leave the car unlocked its a lot easier. With time the lock mech gets all worn. Some people have a bad habit of trying the door once they have locked the car. it all gets a bit fatal
    Jul 2008
    Bristol
    Well, the fact it's going to cost alot if I can't get it fixed by myself.
  1. passenger door want open
    By hairypothead87 in forum Vento - 1994 - 1998
    Last Post: 07-06-2011, 08:26 AM
  2. How To Open 03 Passat passenger door
    By Roy B in forum New Member Introductions
    Last Post: 05-11-2009, 02:59 AM
  3. A4 cab passenger door won't open at all!
    By tristanod in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-02-2009, 11:00 PM
  4. Please Help How to open t5 passenger door when c/l has failed?
    By volksbug77 in forum The Commercial Range
    Last Post: 07-12-2008, 08:04 PM
  5. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
