Thread: 2.4L V6 Cabrio 8H - Over Mileage on MFD and Auto Multitronic Kapput!
  1. Exclamation 2.4L V6 Cabrio 8H - Over Mileage on MFD and Auto Multitronic Kapput!
    Mar 2009
    Sleaford, Lincs, UK
    Well my mate came to me after his car went bottom up! The car battery drained and after jump starting it the car barely showed any sort of life! Here was what I faced:
    Chassis Type: 8H - Audi Cabrio B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 26 36 37 45 46 55 56 57 63
    65 67 73 75 76 77
    VIN: WAUZZZ8H********* Mileage: 115390km/71700miles
    Address 01: Engine Labels: None
    Part No SW: 8E0 909 552 L HW: 8E0 909 052
    Component: 2.4L V6/5V G 0003
    Coding: 0011584
    Shop #: WSC 00672 785 00200
    VCID: 3776C9A73FDD
    14 Faults Found:
    16891 - Idle Control System RPM: Higher than Expected.
    P0507 - 001 - Upper Limit Exceeded - Intermittent
    16885 - Vehicle Speed Sensor: Implausible Signal
    P0501 - 004 - No Signal/Communication
    17944 - Camshaft Timing Adj. Bank2 (N208): Open Circuit
    P1536 - 004 - No Signal/Communication - Intermittent
    17936 - Camshaft Timing Adj. Bank1 (N205): Open Circuit
    P1528 - 004 - No Signal/Communication - Intermittent
    17833 - EVAP Purge Valve (N80): Short to Ground
    P1425 - 002 - Lower Limit Exceeded - Intermittent
    17843 - Secondary Air Pump Relay (J299): Short to Ground
    P1435 - 002 - Lower Limit Exceeded - Intermittent
    17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
    P1421 - 002 - Lower Limit Exceeded - Intermittent
    17923 - Intake Manifold Valve (N156): Short to Ground
    P1515 - 002 - Lower Limit Exceeded - Intermittent
    17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
    P1121 - 002 - Lower Limit Exceeded - Intermittent
    17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
    P1117 - 002 - Lower Limit Exceeded - Intermittent
    17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
    P1114 - 008 - Implausible Signal - Intermittent
    17548 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High
    P1140 - 008 - Implausible Signal - Intermittent
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 002 - Lower Limit Exceeded - Intermittent
    18057 - Powertrain Data Bus: Missing Message from ABS Controller
    P1649 - 008 - Implausible Signal - Intermittent
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No: 01J 927 156 DB
    Component: V30 01J 2.4l 5V RdW 3031
    Coding: 00001
    Shop #: WSC 75800
    VCID: 6FE631C7070D
    4 Faults Found:
    17090 - Transmission Range Sensor (F125): Implausible Signal
    P0706 - 35-00 - -
    18161 - Tiptronic Switch (F189): Implausible Signal
    P1753 - 35-00 - -
    18265 - Load Signal: Error Message from ECU
    P1857 - 35-10 - - - Intermittent
    18259 - Powertrain Data Bus: Missing Message from ABS Controller
    P1851 - 35-10 - - - Intermittent
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 1729
    Coding: 04499
    Shop #: WSC 00672
    VCID: E5CAD3EF55F1
    4 Faults Found:
    01200 - ABS Valves Supply Voltage
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    18256 - Please check DTC Memory of Engine Controller
    P1848 - 35-10 - - - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 L
    Component: A4 Klimaautomat 1116
    Coding: 00100
    Shop #: WSC 00672
    VCID: 2A50E0D3FC6F
    11 Faults Found:
    00797 - Sunlight Photo Sensor (G107)
    31-10 - Open or Short to Ground - Intermittent
    01272 - Positioning Motor for Central Flap (V70)
    41-10 - Blocked or No Voltage - Intermittent
    00601 - Potentiometer On Positioning Motor for Central Flap (G112)
    30-10 - Open or Short to Plus - Intermittent
    01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
    00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    01206 - Signal for Duration of Ignition Off Time
    27-00 - Implausible Signal
    00474 - Control Module for Immobilizer
    49-10 - No Communications - Intermittent
    27-10 - Implausible Signal - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 00000
    VCID: 346CFEAB2EAB
    1 Fault Found:
    00984 - Left Tail Light (M4)
    57-00 - Electric Circuit Failure
    Address 15: Airbags Labels: 8H0-959-655-84.lbl
    Part No: 8H0 959 655 B
    Component: Airbag 8.4EC 1015
    Coding: 0010104
    VCID: 3972CF9F09C9
    No fault code found.
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0308
    Coding: 01041
    Shop #: WSC 00672
    VCID: 3E78DC8310E7
    4 Faults Found:
    01333 - Door Control Module; Rear Left (J388)
    01317 - Control Module in Instrument Cluster (J285)
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8H0 920 930 E
    Component: KOMBI+WEGFAHRS. RB4 D16
    Coding: 00431
    Shop #: WSC 75800
    VCID: 2C5CE6CBF69B
    WAUZZZ8H73K020201 AUZ6Z0B0414627
    4 Faults Found:
    01128 - Immobilizer Pickup Coil (D2)
    01176 - Key
    07-10 - Signal too Low - Intermittent
    00668 - Supply Voltage Terminal 30
    00576 - Terminal 15
    Address 26: Auto Roof Labels: 8H0-959-255.lbl
    Part No: 8H0 959 255
    Component: VSG B6 CABRIO 6185
    VCID: F3EEBDB7EB25
    4 Faults Found:
    02000 - Switch Position
    00466 - Control Module for Steering Column Electronics (J527)
    015 - Cannot Be Tested at this Time - Intermittent
    Address 37: Navigation Labels: None
    Part No: 8E0 035 192 A
    Component: TV/Navigation H03 0209
    Shop #: WSC 07130 552 00000
    VCID: 224008F3845F
    1 Fault Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    007 - Short to Ground
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8H0 959 433 C
    Component: Komfortgerát T7B 1311
    Coding: 06794
    Shop #: WSC 00672
    VCID: 346CFEAB2EAB
    Part No: 8H2959802
    Component: Tőrsteuer.FS BRM 0001
    Part No: 8H2959801
    Component: Tőrsteuer.BF BRM 0001
    Part No: 8H0959801A
    Component: Tőrsteuer.HL BRM 0001
    Part No: 8H0959802A
    Component: Tőrsteuer.HR BRM 1.60
    12 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    01134 - Alarm Horn (H12)
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    00892 - Switch for Trunk Closing Cylinder (F248)
    00955 - Key 1
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    37-00 - Faulty
    01334 - Door Control Module; Rear Right (J389)
    80-10 - Single-Wire Operation - Intermittent
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00070
    Shop #: WSC 00672
    VCID: 040C6E6B3E8B
    Address 56: Radio Labels: None
    Component: Radio H03 0205
    Coding: 0000047
    VCID: 224008F3845F
    2 Faults Found:
    00857 - CD Changer Unit (R41)
    Address 63: Entry Assist,D Labels: None
    Part No: 8H0 959 760 A
    Component: EasyEntry F H13 0010
    Coding: 00005
    Shop #: WSC 75800
    VCID: 356AC3AF25D1
    4 Faults Found:
    01445 - Sensor for Driver Seat Fore/Aft (G227)
    36-00 - Open Circuit
    Address 73: Entry Assist, P Labels: None
    Component: EasyEntry BF H11 X023
    Coding: 00005
    Shop #: WSC 00065
    VCID: 356AC3AF25D1
    4 Faults Found:
    02014 - Switch for Seatback Latch; Passenger Seat (F212)
    After clearing most faults and bringing the car back to life, he is left with the MFD recording 1250 miles when driven say a mile. The miles seem to add up very quickly on the odo too? Is there a correction in VCDS that I have over calculated? In VCDS, Instruments, Channel 03, Consumption Correction, I set this to 85? Is this right, could this be causing over clocking? Is there any other channel like that for milegae correction?
    The other fault was the Auto Transmission is faulty, and flashes PNRD in the MFD. I have set the instruments to tell the car it's manual, therefore taking away the flashing PNRD, this is what he wanted, would this be casuing over clocking? This is the fault:
    P0706 - 35-00 - -
    The other fault was that the tire pressure monitor was flashing on the dash, I also took this off the instruments coding however it disabled the soft top roof, very strange! Please shed some light on this for me! Thanks!!
    07 Passat SEL Sport TDI 170 R
    Deep Pearl Black
  2. Re: 2.4L V6 Cabrio 8H - Over Mileage on MFD and Auto Multitronic Kapput!
    Mar 2009
    Sleaford, Lincs, UK
    After a long drive he said the tire monitor keeps flashing, and he can't reset the mileage on the MFD its stuck on 1250miles!
    Deep Pearl Black
  1. Please Help Nick King's MFSW, High MFD and Auto Hold Retrofits...
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-02-2011, 10:23 PM
  2. Auto, multitronic or tiptronic
    By jackteet in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-11-2010, 03:07 PM
  3. Please Help 1996 Audi Cabrio 2.6 auto
    By definatelymaybe in forum 80 - 90
    Last Post: 09-05-2010, 12:16 AM
  4. A4 2.5tdi Tip auto fuel consumption/mileage
    By mjq1602 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-08-2009, 06:28 PM
  5. best oil for a multitronic auto box?
    By r1dude in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2008, 12:29 AM
