Thread: 2.5tdi changing thermostat - whats involved?
  1. 2.5tdi changing thermostat - whats involved?
    Jun 2011
    Stevenston, United Kingdom
    i have read before that its a big job changing the thermostat on the 2.5tdi, i have the front of the car up on stands as im investigating why my alternator drive belt came off, so the carrier will be going into the service position.
    can the thermostat be changed without having to remove the timing belt and removing the service carrier??
  2. Re: 2.5tdi changing thermostat - whats involved?
    131 Post(s)
    1974 Post(s)
    According to Audi you can do it by sliding the belt almost off of the right hand bank pulley but I have never been able to do it this way so I just take the belt off once I am in there.
  3. Re: 2.5tdi changing thermostat - whats involved?
    Jun 2011
    thanks for the reply crasher, when you say 'according to audi' have you read this somewhere? i have no idea whats involved so how does sliding the belt almost off assist with changing the thermostat?
    have you changed many stats on the 2.5 tdi?
  4. Re: 2.5tdi changing thermostat - whats involved?
    131 Post(s)
    1974 Post(s)
    The thermostat is behind a long cover held on with three M6 bolts. The cover is behind the timing belt so the belt has to be brought forward to allow the housing to be removed, on some engines Audi say that they can be done by sliding the belt forwards on the pulley, personally I can't find enough room to do this. I always fit a new thermostat when I do the timing belt on one of these as they are prone to failure.
  5. Re: 2.5tdi changing thermostat - whats involved?
    Jun 2011
    thanks matey, the thermostat is gone and the timing belt aint due for a while, whether a new thermostat was fitted 48k ago with the timing belt i dont know, maybe it was and they never used an audi one. If you were not able to get into the thermostat without removing the belt then i think i would be best just leaving it for the moment.
  6. Re: 2.5tdi changing thermostat - whats involved?
    Sep 2008
    6 Post(s)
    Quote Originally Posted by rabbie1969 View Post
    Don't think my thermostat was changed - but I'm planning to get it done (along with water-pump) next year. It rarely works, however when under load and pulling a trailer it springs into life and reaches 90 degrees! If it's any consolation the 2.5 TDI rarely overheats as long as you're using G12 and it's at the right level courtesy of twin cooling fans.
    2016 BMW i3 REx (80k)
  7. Re: 2.5tdi changing thermostat - whats involved?
    Jun 2011
    Quote Originally Posted by spartacus 68 View Post
    i would like to change mine and hoipe it gave me more mpg, also come the winter time my heaters aint gonna be so great, ill just put up with it though.
  1. Thermostat location on the 2.5TDI
    By pdimblad in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-02-2013, 08:47 AM
  2. Changing the thermostat on a v6
    By mike ryan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2010, 08:23 PM
  3. Whats involved in changing an ECU?
    By xpeterpx in forum Bora - 1998 - 2005
    Last Post: 17-06-2009, 07:21 PM
  4. changing thermostat on a 1.6
    By caledonianewan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-11-2008, 07:00 PM
  5. Changing thermostat.
    By routers77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-01-2008, 09:18 PM
