Thread: 2000 vw passat 2.5 v6 tdi not starting no lights on dash
  1. 2000 vw passat 2.5 v6 tdi not starting no lights on dash
    Feb 2010
    Lancashire
    Hi hope someone can help i have a W reg 2000 vw passat 2.5 v6 tdi which wont start. Was driving the car and turned it off to go to the shop for 5 mins came back and nothing when you turn the ignition on no lights at all come on the dash.
    When i turn the key the engine is turning over but it will not start.
    I have checked the fuses near the side or the door but they all seem fine can someone tell me where all the other fuse boxes are and does anyone have any info of what else it could possibly be.
    Thanx
  2. Re: 2000 vw passat 2.5 v6 tdi not starting no lights on dash
    Apr 2007
    Congleton
    My 1.9 TDI had a problem a few months ago where it would turn over but failed to start. It turned out to be Relay 219 in the ECU box.
    It costs under £30 from VW.
  3. Re: 2000 vw passat 2.5 v6 tdi not starting no lights on dash
    Feb 2010
    Lancashire
    Is the ECU box on the driver side of the car at the top when you open the bonnet, the one with the umbrella on it?? Also were none of your lights comming on the dash when you were putting the ignition on?
  4. Re: 2000 vw passat 2.5 v6 tdi not starting no lights on dash
    Feb 2010
    Lancashire
    I have just tried the relay 219 but it hasnt changed its still the same looks to be something else.
  5. Re: 2000 vw passat 2.5 v6 tdi not starting no lights on dash
    Apr 2009
    If you are not getting any dash lights and no indicators or wipers,
    it could be the ignition switch
    Regards
    Jim
    Still Crazy After All These Gears
  6. Re: 2000 vw passat 2.5 v6 tdi not starting no lights on dash
    Feb 2010
    Lancashire
    Quote Originally Posted by yaman View Post
    Regards
    Jim
    The headlights are working im not sure about the indicators or wipers havent checked them will check the tomorrow. By the ignition switch do you mean the actual barrel or is there a relay or fuse somewhere?
    Thanx
  7. Re: 2000 vw passat 2.5 v6 tdi not starting no lights on dash
    Apr 2009
    Quote Originally Posted by zedf View Post
    The ignition switch is activated by the key-barrel, but you get at it
    from the other side. Here's a handy vid..http://www.youtube.com/watch?v=nMW-kGXltZQ
    Regards
    Jim
  1. 99 tdi no dash lights turns over wont start
    By pg339 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-12-2013, 04:07 PM
  2. Please Help Sharan 1997 TDI Dash Lights
    By leighhawkins83 in forum Touran - Sharan - Caravelle
    Last Post: 17-03-2010, 12:02 AM
  3. 2000 Golf GT TDI Dash + Starting Problems
    By a1topdog in forum Archive posts
    Last Post: 10-04-2007, 03:54 PM
  4. HELLO ALL ! 2000 w 115 pd tdi problem starting!
    By JAZZBLUE in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-03-2007, 06:57 PM
  5. passat flashing dash lights
    By minty0_10 in forum Passat - Archive Topics
    Last Post: 25-11-2006, 11:18 PM
