Thread: Drivers Door Lock/Central Locking Problem
Results 1 to 8 of 8
  1. Drivers Door Lock/Central Locking Problem
    Jan 2010
    Stonehaven
    My 1998 Audi A4 Avant 1.6 has developed a fault with the drivers door lock and central locking.
    The key will no longer open or lock the mechanism and also central locking also ceased to operate. It is not a remote system, just the manual system of sticking the key in the lock.
    I assume these two issues related and wondered if the fact the mechanical part of locking and unlocking the door with the key has failed it is also linked to some sort of sensor/contact that operates the central locking.
    The door has electric front windows, so should I remove door panel and is there perhaps some mechanical linkage which has become disconnected?
    Any advice would be appreciated as I am just away to sell the car.
  2. Re: Drivers Door Lock/Central Locking Problem
    Jan 2010
    Stonehaven
    Hi Guys and gals,
    Is no-one able to give me any advice or suggestions to my central locking issues??
    You are normally back with some help in hours!!
    Any help would be appreciated as i am hoping to sell car soon and would like to have working before then.
    Cheers if you can give some help.
  3. Re: Drivers Door Lock/Central Locking Problem
    Oct 2005
    Do you have access to VCDS to scan the car for any faults?
  4. Re: Drivers Door Lock/Central Locking Problem
    Jan 2010
    Stonehaven
    Hi Sam,
    Sorry not got access to anything other than my own tools.
    I just wondered if because the key wont mechanically open the lock on drivers door, if this then meant that some sort of contact was not being triggered to open the central locking.
    It is an old 1998 1.6 model so no fancy key fob like my current tdi.
    Thanks for coming back to me.
    Regards,
    Doug
  5. Re: Drivers Door Lock/Central Locking Problem
    Oct 2005
    Sorry, I completely overlooked that part.
    Usually it's the lock mechanism, solenoid or central locking pump. It seems more likely to be the mechanism given your key wont even turn the lock.
    If you can open the door from the inside, take the door card off and have a poke around the lock mechanism.
    If it's the pump itself, there's articles on how to remove and replace it or repair it (from AudiWorld)
  6. Re: Drivers Door Lock/Central Locking Problem
    Jan 2010
    Stonehaven
    Cheers Sam,
    Will have a look now.
    Doug
  7. Re: Drivers Door Lock/Central Locking Problem
    Apr 2009
    If the key is turning, but not doing anything, i suspect a small
    connecting-rod has become detached
    Regards
    Jim
    Still Crazy After All These Gears
  8. Re: Drivers Door Lock/Central Locking Problem
    Jan 2010
    Stonehaven
    Quote Originally Posted by yaman View Post
    Regards
    Jim
    Hi Jim,
    That is exactly the problem. Away to have a look shortly.
    Regards
    Doug
  1. Question central locking only opens drivers door??
    By domaldinio in forum Golf MK4 - 1999 - 2004
    Last Post: 29-08-2017, 06:51 PM
  2. Question Remote Central Locking does not lock/unlock drivers door
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-05-2011, 09:25 AM
  3. Please Help Passenger door lock/central locking problem
    By kahunajb in forum Golf MK4 - 1999 - 2004
    Last Post: 28-10-2010, 08:32 PM
  4. Central Locking Not Locking Drivers Door
    By davieb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-11-2008, 10:37 PM
  5. Central Locking from Drivers Door Panel
    By damjee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-05-2008, 10:54 AM
