Thread: water collecting - help please
Results 1 to 10 of 15
  1. water collecting - help please
    Mar 2010
    liverpool
    water is collecting in the area under the scuttle. is there a run off area that maybe blocked. i have looked and cleaned away any debris and all seems clear but am i missing something. scuttle not damaged so is it normal for water to collect in this area. thanks in advance
    1.8T, votex bodykit, 18" RS4's, tinted windows.
    scouser, but car was bought and paid for.
  2. Re: water collecting - help please
    Sep 2008
    6 Post(s)
    Assuming we're talking about the same area (bulkhead where battery is located)? This is a well-known fault that is responsible for damaging brake-servo, etc. There are two rubber grommets in the base of the bulkhead under the wiper motor. You'll need to remove rubber strip and plastic trim in engine bay to access. Remove the rubber grommets completely to clean. Using a mild detergent, clean the area thoroughly then hose it clean. Only re-insert the grommets, once you've removed some of the rubber in the middle, or exactly the same thing will happen again.
    2016 BMW i3 REx (80k)
  3. Re: water collecting - help please
    Mar 2010
    liverpool
    thats great, will look at that asap (or to be more exact, when kids go back to school) have a list of faults with car and figured this 1 most likely to do damage and needs sorting.
  4. Re: water collecting - help please
    Dec 2009
    southampton uk
    Quote Originally Posted by aaudi4 View Post
    Dont know if its raining hard where you are but if so and the car is out with blocked drains you are going to have water overflowing into the car
  5. Re: water collecting - help please
    Mar 2010
    liverpool
    not had rain of any description for a while, but i have cleaned area and currently bone dry for now.
  6. Re: water collecting - help please
    Sep 2011
    Washington (NE) UK
    I had a similiar issue when I had a Superb. The seal at the bottom of the pollen filter had perished. I believe that the lay out is the same might be worth checking this, I fixed it with plumbers mate putty using as a seal.
  7. Re: water collecting - help please
    Mar 2009
    Kidderminster, Worcestershire and Tewkesbury, Gloucestershire
    it's not uncommon to just push the grommets out completely and leave them out. Much less chance of them blocking up again.
    2007 A6 2.7TDi Avant Manual S-Line
    2003 A4 B6 Avant 1.9 TDi Quattro Sport, Manual -Sold
    1999T A6 C5 Avant 2.5 Auto, 244k -Sold
    2005 STM Phoenix R1 powered, 1988 205 Gti 16v tarmac rally car . . and a few motorbikes
  8. Re: water collecting - help please
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Quote Originally Posted by philfingers View Post
    That was the solution suggested in the Audi tech bulletin - car on ramp - just pull the buggers out
  9. Re: water collecting - help please
    Dec 2009
    southampton uk
    Quote Originally Posted by danclyon View Post
    I have since seen Crashers post that the bungs are actually valves designed to keep fumes out and s/b cleaned and replaced!!!
  10. Re: water collecting - help please
    Aug 2007
    15 Post(s)
    Interesting, as they assured me the bulletin was to remove them! Not sure whey there'd be fumes in that area though.....nor should there be any leaking down below if the exhaust is all in good shape....
  1. Water collecting under fuel flap
    By halfbee in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-09-2010, 09:27 AM
  2. Question Water collecting in rear door
    By jgalvin in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-01-2010, 09:33 AM
  3. water collecting on rear passenger door sill
    By kennyboy in forum Passat CC
    Last Post: 25-11-2009, 10:22 AM
  4. A6 Avant (C5) Tailgate hinges collecting water
    By NickPicks in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-11-2008, 04:41 PM
  5. water collecting in battery compartment
    By Topcat65 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-06-2008, 11:53 PM
